Old 11-05-2012, 08:29 AM   #8
Lrn2Go
Lrn2Go's Avatar
Lrn2Go is an unknown quantity at this point
Okay... just to follow up in case someone runs into this problem in the future... here's the solution.
My issue (if you can't tell in the video) was that I had a 4-wire female plug on the side of my fuse-box that the transmission harness needed to plug into. The issue was, the transmission harness had an 8-wire male plug. So... since I had the fuse box off of the JDM sr20det swap (and not the USDM ka24det trans harness), I cut off the 8-wire female plug from it.
The solution was to just clip the 4-wire female plug off my fuse box and match up the colors. There is a white-pink, yellow/white, yellow/black, and a yellow/blue wire on both plugs... so you solder them together. The other 4 wires I just taped up. Yury with Wiring Specialties says this is just fine... and the car seems to be running fine now. :nod:
'08 350z Grand Touring - DD
'89/92/93 240sx Coupe - "Frankenstein" project
Lrn2Go is offline   Reply With Quote
