Old 11-16-2012, 03:55 PM   #1
Slo_lo_zenki
Slo_lo_zenki is an unknown quantity at this point
s14 hid help.....
okay i know i found a thread last time i looked, but i couldnt seem to find one this time.... i have HIDs in my s14 and the headlights turn off completely when the brights are turned on.... hoping to find the info on how to wire in a relay to keep the brights usable or from killing the headlights when the brights are bumped on...... any help or a link would be awesome
and if it matters i have no bulbs in my brights at the moment
thanks guys/gals
Slo_lo_zenki is offline   Reply With Quote
Old 11-16-2012, 04:02 PM   #2
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Not like you need brights with HIDs anyways. Mine does the same. But the HIDs are brighter. Want brights get a hi/low HID kit? Blind everyone lol
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 11-16-2012, 04:07 PM   #3
Veltall
Veltall's Avatar
Veltall is an unknown quantity at this point
kouki or zenki headlights?
Veltall is offline   Reply With Quote
Old 11-16-2012, 05:02 PM   #4
Slo_lo_zenki
Zenki, and my selector is old, so if i lightly bump the brights when usi.g turn signals, my headlights turn off.... Not too safe at night
Old 11-16-2012, 06:40 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You could use this if you plan on using relays...
http://zilvia.net/f/tech-talk/359768...am-wiring.html
CLICK HERE!!!
Old 11-16-2012, 07:03 PM   #6
cotbu
cotbu's Avatar
Wolstentech TDR will fix you up. The reason for running a solid state fast switching relay besides convenience is, it keeps the HID ballast from cutting off and on. when switching from from high to low. Oh yeah it's true, I hardly ever use high beams, but for inspection I wanted a working system.
Old 11-16-2012, 07:19 PM   #7
Slo_lo_zenki
Relay wiring is what i was lookin for
thank you
Old 11-16-2012, 07:29 PM   #8
fliprayzin240sx
Lemme double check my relay tomorrow, I might have done something different to that, just to make sure.
I did the relay wiring when I did my kouki conversion.
CLICK HERE!!!
Old 11-21-2012, 12:41 PM   #9
Slo_lo_zenki
i followed a relay install write up on here, and now my lights never turn off
Old 11-21-2012, 12:55 PM   #10
Slo_lo_zenki
i used this write up..... http://zilvia.net/f/tech-talk/359768...am-wiring.html
Old 11-22-2012, 09:38 AM   #11
fliprayzin240sx
You did something wrong, the High Beam should act as the trigger on the relay. Listen to the relay, you should hear it click on with the high beam on. If it staying on all the time, you got the wires backwards.
CLICK HERE!!!
Old 11-22-2012, 09:56 AM   #12
Slo_lo_zenki
I fixed it, the diagram in that link was wrong.. hids working great now
Old 11-23-2012, 07:04 AM   #13
fliprayzin240sx
Yah, I know I did something different, just cant remember what exactly. I kept blowing my damn fuse when I did it at first. But figured, that wiring will give you a start on needs to be done.
CLICK HERE!!!
Old 11-23-2012, 08:16 AM   #14
silviaks2nr
silviaks2nr's Avatar
1) do bixenon projector retrofit
2) purchase a quality H4 relay harness (with a diode between low and high trigger)
