#1 | |
![]() Join Date: Nov 2010
This can be checked pretty easy too, but you need a multi meter
Z32 with lq4 swap Desert Street Scene || Dssevents.com |
UPDATE:
Conducted another boost leak check, found a few pin hole leaks in silicone boot seals, sealed them up, and now no leaks(tested to 15psi). Chased out the Knock Sensor code. Can't seem to find anything wrong. When disconnected she runs no differently. Chased out the MAFS code. Again, can't seem to find anything wrong. I have noticed that during idle when she stumbles(feels like a misfire) that the A/F ratio leans out temporarily. I am hoping to borrow a know good fuel rail, FPR, and injectors from a friend and see if that's the issue. Might not be able to get my hands on that until the day after tomorrow. I'm open to other suggestions in the mean time, I've got a day to kill anyway. Jake |
U should spend a few bucks and buy a multi meter, You can test so many things with it! so many activities with a multi meter.
Honestly tho, if u get one Id start testing voltage and continuity on the MAFS,TPS, and CTS.
Tags |
manual boost controller, mbc, sr20det, stalling |
