Old 12-31-2012, 10:41 AM   #1
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
Originally Posted by Frank_Jaeger View Post
He has R33 calipers. Either I fail at reading, or you fail at reading. Everyone who responded with fail comments about stock ebrakes also fail at reading.
OP you could've just done a simple google search. Get an R33 ebrake cable.
R33 Ebrake cable LH
Thank you, that's what I was asking.
FourtyKid is offline   Reply With Quote
Old 12-31-2012, 11:57 PM   #2
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
R33 rear calipers are the same as Z32 calipers, unless they're the Brembos. In any case you have to have the entire e-brake assembly to hook up any stock e-brake. You DO have the e-brake assembies, backing plates, and anchor pins right? The anchor pins are correct for your hubs right? They come for tabbed hubs and non-tabbed hubs...
Old 01-01-2013, 12:14 AM   #3
FourtyKid
FourtyKid's Avatar
I do not. I need to buy the assembly (God I'm a dumbass sometimes). Another question. Let's say I just wanted to run a hydraulic e-brake and forget about the stock cable e-brake. I wouldn't need that whole assembly, would I? It would use this line instead, correct? Because then I could just connect it to the master cylinder and run some stainless steel lines and I'd be good to go.
