Old 07-01-2004, 01:18 AM   #31
BobbyBoy
BobbyBoy's Avatar
BobbyBoy is making a name for him/her selfBobbyBoy is making a name for him/her self
Send a message via AIM to BobbyBoy
Welded diff here too, I can assure anyone, the welds will not break if done by Luke, the gears are like a solid mass of metal now. Have it done RIGHT by the guy thats been doing this for awhile. I have seen other welded diffs, and the welds look like little rabbit turds holding the gears together. I could see those diffs breaking in the future. As far as daily driver factor? Id say its similar to any other 2-way. Some may not like the way it operates, but its fine with me. Then again I daily an SR with no interior, only one seat, no AC or heater, ghetto rigged speakers, a leaky ticking manifold and dying turbo that spews burnt oil smoke from my tailpipes about 5 mintes after startup.
BobbyBoy is offline   Reply With Quote
Old 07-01-2004, 02:38 AM   #32
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Booo Ya. Bobbys hard core
blu808 is offline   Reply With Quote
Old 07-01-2004, 10:13 AM   #33
BobbyBoy
BobbyBoy's Avatar
Yea, but I still need to hollow out my doors to be as hardcore as you.
Old 07-01-2004, 10:53 AM   #34
blu808
blu808's Avatar
ha ha maybe. you missed the hwy9 drive last night, it was fun.
Old 07-01-2004, 12:19 PM   #35
BobbyBoy
BobbyBoy's Avatar
Damn had my hand down my pants instead, next time call me up I wanna see the lights show from your exhaust.
Old 07-12-2004, 03:28 AM   #36
Buffalo Daughter
Buffalo Daughter's Avatar
Buffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enoughBuffalo Daughter will become famous soon enough
i think im pretty down to run a weld'd diff but i drive a lot. Hows the all around drive bobby? I don't doubt luke's skills welding. Seems like a very good alternative right now since im gitty about driving in the next drift event again. I mean if it functions the same and no clunking sound or what not then im pretty sure im down to get it asap. Ha maybe even this week since im getting my paycheck in 2 days.
Thanks
Jud
kick rocks.
Buffalo Daughter is offline   Reply With Quote
Old 07-12-2004, 08:23 AM   #37
orion::S14
orion::S14's Avatar
Allright...I welded a spare diff I had lying around a couple months agao, really just for the fun of it...I decided if I had a spare hour or so, I'd swap it into my daily driver (N/A) S13 and see how it acted...
So I did that this weekend...and it's rough.
When I first pulled out of the driveway, I noticed it was hard to steer...when both rear wheels are pulling the same direction, the front's have to fight to make it turn.
Once I cut it full right to back into the street, there was nasty clunking and the rear inside wheel was hopping as it skidded along, trying to stay the same speed as the outside tire. Nasty noises, lot's of vibration, and the shifter was almost hitting the sides of the hole in the underbody due to all the movement.
It drove OK, but every slow corner it hopped and skipped, with a pronounced THUD-clunk-THUD.
Now, if you gave it throttle entering the corner to get it to break loose and just slide a little, there was so much rear grip that it just pushed the front out...understeer like crazy.
If you clutch kicked it, or hammered it from a stand still, it would slide out nice and smoothly, it that part was great...but really no different than with my VLSD in the S14.
I put about 30 miles on it, including a couple runs trough a new neighborhood (new curvy roads, but with no houses), and while it was OK for quick "grip" driving and a little sliding around, it SUCKED on the street. And I'm not saying that b/c I'm a little b!tch...I can put up with just about anything for decent performance, but this was just rediculous.
That being said, if you only tracked your car, or drifted A LOT, this may be acceptable.
And with shitty rear tires, it may be better...b/c it would just squeal and slide, rather than hop madly...but with somewhat-sticky FM901s, it was bad.
So my opinion is:
Welded diff = Decent, but not worth it...unless you run hard rear tires for drift. With any grip in the rear, it's just too violent on the chassis.
Case in point: My drivers door lock didn't work the next day after putting miles on the car...the rod had fallen out of the lock assembly from all the hopping and shaking.
And as I said, my VLSD equipped S14 performs in a similar manner...slides just as well, breaks both tires every time, etc...but without bad streetability.
Just wanted to post a review...you may agree or not, but I figured some people may want a review.
- Brian
Old 07-12-2004, 12:18 PM   #38
Buffalo Daughter
duely noted. Yeah ive been in cars that have had welded diffs. One did the same thing you explained. It Clunked everywhere. It hopped a little too. It did break loose great but the driveability licked balls. I was hoping that the diffs that luke's been welding doesnt do the same thing .
jud
kick rocks.
Old 07-12-2004, 02:38 PM   #39
blu808
blu808's Avatar
It depends on the condition of your bushings. It you have really worn bushings then it will clunk alot more, overall, bobbys car has over 100k on it with stock bushings, and it works fine.
After having welded diffs in a ton of cars i can say that it doesnt clunk any worse than a kazz.
Old 07-12-2004, 06:09 PM   #40
Buffalo Daughter
i think i just might go the way of the welded locd diff right about now.
i might be calling you again soon luke. Thanks for the info guys.
Jud
kick rocks.
Old 07-12-2004, 06:19 PM   #41
Var
Var's Avatar
Send a message via AIM to Var
I have the tomei= Kaaz with shims=more agressive lock but basicallly the same. It clunks like CRAZY!! it's to the point where i dont like driving it around town..even after the proper break in procedure. This diff was made for racing and that's what i'll use it for from now on. I'm taking the tomei diff and putting into my drift car, and putting the VLSD onto my street car. The vlsd doesnt work that good at low speeds but better like at the top of second or 3rd gear. It's perfect for street use though. Also if i knew i would have a dedicated drift car, i may have welded the diff myself, instead i spent 800 bucks on the Tomei. O well....
Hi
Old 07-12-2004, 07:38 PM   #42
Ricer240sx
Ricer240sx's Avatar
Ricer240sx is an unknown quantity at this point
Send a message via AIM to Ricer240sx Send a message via MSN to Ricer240sx Send a message via Yahoo to Ricer240sx
its not too bad, but i dont nessisaraly like it, i onl drove with it throug the city for a little bit but i know ill be saying bye bye to a lot of tires, and i hate the hopping that comes along with it when u turn!
00 impreza 2.5rs sedan...dd
00 impreza 2.5rs coupe....EJ255, goin rwd!!
Ricer240sx is offline   Reply With Quote
Old 07-12-2004, 08:10 PM   #43
blu808
blu808's Avatar
Welcome to the world of having any lsd besides a vlsd
Old 10-14-2004, 02:52 AM   #44
Drunk Bastard
Drunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really niceDrunk Bastard is just really nice
Send a message via AIM to Drunk Bastard
I Love My Weld Locd Diff!
Drunk Bastard is offline   Reply With Quote
Old 10-14-2004, 09:23 AM   #45
inertia
inertia is an unknown quantity at this point
I LOVE my welded diff. Got it from luke hehe. Put it in last sat. its been great, slides like crazy. and i have noticed that it corners faster is you press the throtle. So far no regrets. all those dudes on NICO are telling me that its gonna compromise handeling and that its only for the hardcore. what a bunch of panzzies. WELD LOCD DIFF VER3
Hey Luke, i want a sticker!!!!!i'l email you about it.
inertia is offline   Reply With Quote
Old 10-14-2004, 06:32 PM   #46
AN89HATCH
AN89HATCH is a well-known jackass
whats it like driving a car with welded diff in the rain? will it be to dangerious?
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 10-14-2004, 07:49 PM   #47
SR_TeXaN
SR_TeXaN's Avatar
SR_TeXaN is an unknown quantity at this point
Can you say Curb.....
SR_TeXaN is offline   Reply With Quote
Old 10-14-2004, 07:57 PM   #48
driftstyre
driftstyre's Avatar
driftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond repute
Send a message via AIM to driftstyre
If a diff is welded correctly and with enough but not too much heat, it will never break. Also, slow cooldown is essential for dense, treated steel.
For anything over 30mph its tough to tell the difference from a decent clutch diff with average preload. Off throttle understeer at lower speeds is a small problem but for drifting there is really nothing better. The predictibility and consistency of a locked diff is unparalleled. The majority of circuit/rally cars in the 70's/80's and early 90's used spools instead of diffs for reliability under power. The 97 spec Impreza WRC used a welded rear diff over an active or clutch type due to its consistency and reliability. With carbon diffs and the advances in electro/hydraulic diffs its not really an issue anymore. Welded diffs rule!
driftstyre is offline   Reply With Quote
