Old 02-01-2013, 09:59 PM   #1
Frank_Jaeger
Taking the IACV off is very easy. Just need a regular open / closed 10mm wrench and a 10mm socket / socket wrench. 4 Bolts, a couple clips, and a hose. BAM. Then you can clean it for real. Soak it and scrub it.
Make sure you make yourself a gasket for it, otherwise you'll have a mild vac leak.
Frank_Jaeger is offline   Reply With Quote
