Old 02-02-2013, 05:47 PM   #6
suspectu1
suspectu1 is an unknown quantity at this point
hey, I actually wrote a how-to on wiring a fuel pump from a relay, without bypassing the original circuit design, just bypassing the original wiring. look for my posts in this thread http://zilvia.net/f/tech-talk/488793...d-bad-cas.html
there's nothing wrong with your diagram, btw, but there is a better way to do it. If you follow my advice from the link above, you'll have it wired so that the ECU can switch the pump on and off through the ground. This will prevent you from blowing up in case you get into a bad accident where the engine dies, you're unable to reach your pump switch, and so the fuel pump keeps gushing out fuel Having the ECU switch the fuel pump's ground would prevent that. Lemme know if you need more help
suspectu1 is offline   Reply With Quote
