Old 02-03-2013, 05:16 PM   #3
kcook737
kcook737 is an unknown quantity at this point
Originally Posted by mikevskater View Post
The distributor positioning sensor might be bad, you have to take the cap off the dist. then the rotor, then the rubber seal, then there are two Philips screws. remove those and look at the disk inside. If its damaged in ANY way that would cause and issue.
If its not that start looking into your injectors.
Ill check that sensor out and get back with you. And I checked the injectors by unplugging one by one with the car running. All made a change so I ruled them out as an issue. Also did the same with the maf sensor and it made a change as well.
Thanks for the reply
kcook737 is offline   Reply With Quote
