Old 07-19-2004, 06:03 AM   #1
MorganS13
MorganS13 is an unknown quantity at this point
Angry How hard is it to replace a drivers side door window?
Just woke up and found that someone decided they wanted to break out my window and steal my little sub/amp.. (while leaving my head unit of course) Luckily the only damage is that I no longer have a window in my door. I located a few windows for $20 at local junkyards, but I have never had to replace a window myself. How hard is it if I did it myself? If not, what should I expect to pay to have this installed? Are the windows the same for power and manual operation?
MorganS13 is offline   Reply With Quote
Old 07-19-2004, 07:21 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
it's not too bad. Pull door panel, and then unbolt the old window remains from your window regulator. reverse for install. don't forget to get all the glass out of your door. Windows are exactly the same between power/manual.
Same for S14 (but s14 is not interchangeable with s13.)
Old 07-19-2004, 10:21 AM   #3
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
you ever get your rear hatch tinted?
if not, you will have 2 un-tinted windows :P
but really, that sucks ass man
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 07-19-2004, 10:42 AM   #4
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
yeah once you get the door panel off all you have to do is see how its connected to the regulator which is a couple of bolts. pretty easy to do
ch1873857 is offline   Reply With Quote
Old 07-19-2004, 01:20 PM   #5
PSI240SX
PSI240SX is an unknown quantity at this point
All it really is is 4 10 mm nuts that hold the window on, lower the window all the way down, and you can access them pretty easily, undo the nuts and the window will come right out.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 07-19-2004, 01:36 PM   #6
MorganS13
Good deal.. just picked up my $20 replacement window, time to get to work.
Thanks for all of the help, I'm just glad it wasn't the Audi..
Old 07-19-2004, 01:40 PM   #7
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
it's a peice of cake! 3 days after my car my alarm went off in the middle of the night and i find broken passanger side window... easy to replace, it's the alignment part that i still havn't got it right... everytime i roll down my window it shakes when it's coming down...
240meowth is offline   Reply With Quote
Old 07-19-2004, 03:17 PM   #8
MorganS13
As easy as could be.. took about 15 minutes of dissassembly/assembly, and another 15 minutes cleaning pieces of glass out of the door.
Old 03-02-2013, 07:49 PM   #9
brucetrann
brucetrann's Avatar
brucetrann is an unknown quantity at this point
Help.. I can't get the driver side window on -_-
brucetrann is offline   Reply With Quote
