Old 03-10-2013, 10:58 PM   #1
slide2unlock
Trader Rating: (-1)
slide2unlock is an unknown quantity at this point
Feedback Score: -1 reviews
Externally gated gt2871r tial 44mm tune
So, I have an sr tuned on a gt2871r on 16psi making 300 Ish hp, I wanna go externally gated and now have a modded manifold and tial 44mm external waste gate. I haven't installed it yet, but I was wondering if I installed my external wastegate if it would screw with the tune, I just don't want it to lean out and explode, my tuner won't be back in the country for another 2 weeks and I have a drift event I wanna hit. Should I be alright? Cause my stock manifold is cracked and not holding boost, which is why I'm switching to the new manifold. Help would be greatly appreciated.
slide2unlock is offline   Reply With Quote
Old 03-10-2013, 11:03 PM   #2
ryandh
ryandh is an unknown quantity at this point
you would need a new tune. What size spring in that 44mm?
ryandh is offline   Reply With Quote
Old 03-11-2013, 01:23 AM   #3
oni jake
oni jake is an unknown quantity at this point
You'll most likely be fine. Do you have a wideband?
An ECB with adjustable gain is going to help you the most.
oni jake is offline   Reply With Quote
Old 03-14-2013, 03:15 PM   #4
slide2unlock
Trader Rating: (-1)
So I traded the 44mm setup for a 38mm setup, it has a 10 pound spring in it. This manifold is all ceramic coated and whatnot, and I got cash ontop. I have a wideband, and an e-boost street e40, I just don't know if I should swap the manifold off for this modded one.
Old 03-14-2013, 10:59 PM   #5
derass
you will be fine. the external will flow more exhaust, limiting the boost pressure quicker than with an internal. if the car was spiking before and the tune could handle it, it wont be a problem now.
Old 03-15-2013, 08:56 AM   #6
Def
Not a problem. If anything you'll flow some more air, maf will take care of it, and timing will go down at the same boost pressure.
DEFSPORT
Old 03-15-2013, 09:33 AM   #7
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
Shouldnt you be making more than 300ish?
rwtf is offline   Reply With Quote
Old 03-25-2013, 09:24 AM   #8
slide2unlock
Trader Rating: (-1)
I'm making 317, but my boost pressure always drops from 16 to 14 lol, which is why I'm going externally gated. I made a block off plate for the internal wastegate, so we will see what happens tomorrow
Old 03-26-2013, 03:06 AM   #9
Croustibat
you got another problem if your 2871 cant maintain 16psi ... it should be able to push 22psi at least at redline.
Old 03-26-2013, 09:50 AM   #10
slide2unlock
Trader Rating: (-1)
I think it's my wastegate a fault, I fixed it, it can hold 16 psi happily.
