Old 04-29-2013, 08:13 PM   #1
xzero101
xzero101 is an unknown quantity at this point
Bee R Install on a 240SX S14 OBD1
Ok so I searched everywhere and there is no correct guide to install a Bee R Rev limiter on a OBD1 S14.
Does anyone here knows how to wire this? I just need the ECU pin#s
Thanks
xzero101 is offline   Reply With Quote
Old 04-30-2013, 09:31 AM   #2
sr20det-s14
sr20det-s14's Avatar
sr20det-s14 is an unknown quantity at this point
look it up in the fsm if your just needing a pin out of the ecu
sr20det-s14 is offline   Reply With Quote
Old 04-30-2013, 09:39 AM   #3
xzero101
Thanks but I need someone to give me the correct 4 pin#s where I need to hook up the wires.
Because on some threads they hooked up the ignition wire to the cas and some to the ignition switch. I just wanna make sure whats the right one
Old 04-30-2013, 03:12 PM   #4
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
I have never tested this.
DennisC is offline   Reply With Quote
Old 04-30-2013, 03:15 PM   #5
xzero101
That's obd2 :S
Old 05-02-2013, 11:24 PM   #6
DennisC
DennisC's Avatar
I thought all S14 had the same ecu pinout.
Old 05-03-2013, 03:44 AM   #7
Paint209
Paint209 is an unknown quantity at this point
I never seen that pinout before. ill give it a try tomorrow on my s14 obd2.
Paint209 is offline   Reply With Quote
Old 05-03-2013, 09:21 PM   #8
Paint209
does not work.
Old 05-03-2013, 09:25 PM   #9
xzero101
The same unit still works in a sr setup
Old 05-03-2013, 09:57 PM   #10
Edwin562
Edwin562's Avatar
didnt obd1 converted to obd2 in 94?
Old 05-04-2013, 09:23 PM   #11
sr20det-s14
most cars it was standard in 96 on up to have obd2
