#3212 |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
interesting. I'm currently running a gt3071r .63 and S4 cams. The power is great once it kicks in, but I hate waiting for it.
I was thinking of changing the turbo to gt2871r t3 housing .63. How is the spool on that compared to t25 .86 A/R
http://essencegarage.wordpress.com/ |
#3213 |
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
It's hard to know the difference because a lot of things are different on my car now, but when I was running same turbo w/ T2 .86 iwg...hitting 18lbs was around 4200rpm. The actual T3 .63 house might be bigger than my housing. ATP states my housing flows like a t3
#3214 |
hey guys so ive decided to keep my bottom end stock, not open it just yet, so im thinking of staying stock bottom since the mileage was under 30k, ported head, 264 cams, stock springs, stock valves, lifters, chain, should i do adjustable cam gears, gt2871r, ported stock intake mani, megan top mount ex mani, stock tb, 750cc injectors, 255 pump and a call in custom tune from jw, what u think reliable efficient 350ish hp setup???
#3218 |
yah with rb26s you have to cut into the firewall not down..lol are top mounts that bad?? so since im not boring the block, should i still run a 1.5 apexi gasket?.. still running arp head studs and possible arp rod bolts... what u guys think?
#3220 |
#3221 | |
![]() Join Date: Nov 2003
Just leave the insides of the engine stock dude.
-Kyle ![]() |
#3223 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Don't go metal head gasket on a stock bottom end with arp head studs. Would you rather a rod go from pressure or a head gasket? Stick with OEm paper.
IG/TikTok-ThatS14_Z06guy |
#3227 |
![]() Join Date: Jun 2010
I've been searching this thread without much luck as too how far can i push the motor on a stock head gasket.
Car made 320whp at 15psi, but would like to go for 16-18psi. Using 555cc injectors, havent logged the DC's but probably getting up there. Next stage of upgrades will be: Metal HG, Studs, Inatake Manifold, Cams and 740cc injectors. Hopefully, it will make close to 400whp at 20+ psi |
#3228 |
Detonation will pop a head gasket long before hp will. I dont know why anyone would crack open a factory engine to replace a head gasket that isnt blown.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#3229 | |
Msg length
-Kyle ![]() |
#3231 |
Why? Is there something wrong with it? Your motor do what you want but I would never crack open a factory sealed motor unless I had to.
#3232 |
These aren't 302's lol
Once you take the head off, and let the JDM fairy dust out, it'll never run good again. Fact of life. Seriously, don't replace a head gasket until its broke. And just so you know, if you do your wiring, fuel lines, vac lines, and install clean enough, it should only take 30-45 mintues to pull the engine and trans out...
-Kyle ![]() |
#3234 | ||||
![]() Join Date: Sep 2005
Also we could use a head gasket database, with images to compare old, failed or just used head gaskets. MHO
#3235 | |
![]() Join Date: May 2011
Also a intake manifold is pointless if your not making 400+. You gain top end power and lose your low end tq. (It does make your engine bay cleaner and cleans up the VAC/Fuel lines tho) Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
#3236 |
are you guys running adjustable FPR's? what is your setting at?
just picked up a nismo. I have a walbro 255, and it's currently at stock setting. i can't check, but i have another FPR with a gauge on it. i might just hook it all up, though it's unnecessary lol. it is one of those ebay type's, it's from DNA motoring. has a gauge so i'll at least know what PSI i'm at. |
#3237 |
![]() Join Date: Sep 2010
Trader Rating: (41)
![]() Feedback Score: 41 reviews
These guys are correct about the OEM head gasket, that thing will hold a hell of alot. I've been running the same SR engine for about 3yrs now with multiple different turbo setups & alot of abuse and it still keeps taking it. Have ran the T25/T28, 30R and am now currently running a 2871R. Have had issues in the past with wastegate and ran infinite boost a few pulls, some overheating issues and still this engine keeps taking it!
I know an aftermarket head gasket/studs is a great upgrade, but atleast wait till you blow yours. DON'T FIX IT IF IT AIN'T BROKE! I'm just waiting for mine since I already have those parts on standby lol. |
