Group Buys Dedicated Forum for Group Buys. |
#31 |
![]() Join Date: Nov 2003
Have you considered making http://zilvia.net/f/chat/515491-carb...ck-covers.html to go with it?
-Kyle ![]() |
#32 | |
We do "Awesome" |
#33 |
I'd like one, cause as of right now, the only carbon piece in my engine bay is going to be the cooling panel I am getting form you. A carbon coil cover might help tie it all together. If you could do one and still maintain the raised embossed "INTERCOOLER TURBO" on there like factory, that would be awesome.
-Kyle ![]() |
#34 |
![]() Join Date: Aug 2002
I may be interested in s13 silvia and s15 version. You should consider making the s13 pop-up version too.
#39 |
Just a quick update, I wanted to have some ready to ship monday, but im having some issues with the finish. Heres a picture of the cooling panels in process.
We do "Awesome" |
#43 |
Got you down
Quick update. I have one done cleared and am in the process of doing 3 more. This is to make sure I can achieve a constant finish all across the board. BTW any one have an S13 or S14 sunroof glass for sale?
We do "Awesome" |
#44 | |
I'd like to see pics of clears vs. not, cause i think I might rather have mine not cleared.
-Kyle ![]() |
#45 |
It will still be a upgrade. I want to make sure I have a consistent product. Non of this "bad batch" problems other companies have. In order to do this i need to make a large number of panels trying different things. I don't want to put up a picture of one good product like many other companies do and have the customer end up with something that is not the same. Hince why I am clearing alot more then just one.
We do "Awesome" |
#46 |
Ok cool, cause I think I might rather have a non cleared one. Would obviously like to see final side by side pics. But I probably don't need clear.
What is the shipping ETA you think?
-Kyle ![]() |
#47 |
I got a chance to look at one of the 9k Racing panels in person recently. It's actually pretty thin and the bottom of it is the usual fiberglass with what looks like a layer of carbon fiber on top to make it look nice. (I'm assuming this is what is meant when people say companies like VIS don't make real carbon fiber hoods, it's really all fiberglass with a layer or two of carbon fiber on top for looks). The hood latch area also needs to be notched/dremeled because it doesn't match the hood latch location. In all, it's what should be expected from a "made in china/ebay" product.
Anyways, after looking at that piece, I'm hoping yours is of much higher quality. I don't know too much about carbon fiber manufacturing (need to learn more about kevlar, dry carbon, etc.), but I do know that fiberglass with a layer of carbon is not real cf. Garage Defend is probably real cf. Can you explain some carbon fiber basics? I'm assuming yours is full carbon throughout and you mention vacuum bagging? What is that? Will it have the carbon weave appearance on the bottom and top of the panel and basically all around? |
#48 | |
Vacuum bagging is a process where the laminate is sealed in a plastic film along with other materials where the air is pumped out. the pressure differential between the outside of the bag and inside creates compacting pressure, this pressure in-turn compacts the laminate under the film bleeding off all excess resin and air. Creating a a part that is both light and strong. For a part to be both light and strong it needs to have little resin as possible without having too little that it does not saturate the fabric. 70 percent fiber to 30 percent resin seems to be the ideal rati for strength to weight to cosmetics. Regular vacuum bagging has about a 60-65% fiber to resin, infusion/prepreg is about 70-30. Wet layups which is standard on 90% of parts bought can be any where from 10-50% fiber to resin, carbon fiber basics, there is way to much to cover in a for sale post. really it should be its own post. Basically if your buying a "carbon fiber" hood for less then 1000 bucks its not carbon most likely not even remotely optimized for strength to weight, meaning its #1 design factor was to do it for cheapest possible, don't even get me started on the scam that every one uses "dry carbon" ![]() I have a original garage defend panel. its just 1 layer of carbon with a carbon matt behind it.The part it self is about the thickness of 4 sheets of paper.If carbon is done right it does not need to be thick to make a suitable part. Makeing parts thick kind of defeats the purpose of using carbon.
We do "Awesome" |
#50 |
Can you comment on Seibon's "rolled edges" for premium look? Does anyone sell a carbon product with sharp jagged edges like they just cut it? VIS hoods I've seen have smooth edges. Is Seibon's "rolled edges" just marketing? The edges on your product will be smooth too?
#51 | |
We do "Awesome" |
#54 |
If I can still get a CF panel at the group buy price I'll take one.
Everything you need to know about the S-Chassis ![]() -- CollectorsEdition.org -- | -- 240sxONE.com -- |
#55 |
here is a picture of a cleared panel. I am wating on some materals to make some non cleared ones then i will take some high res pictures with the entire batch.
The crazy heat is making it difficult for me to make anything right now. Hopefully it will cool down enough where i can start making these things again. ![]() ![]() ![]()
We do "Awesome" |
#56 |
![]() Join Date: Dec 2002
Trader Rating: (39)
![]() Feedback Score: 39 reviews
It looks like it turned out pretty well. When you get the others finished, would it be possible to see pics of both installed? So I can better visualize which finish I would like?
1997 Nissan 240sx 1991 Nissan 240sx hatch |
#60 |
yup, thats the plan. I am trying these on a few diffrent cars at the moment, adjusting holes so that the panel will fit on cars with minor damage.
We do "Awesome" |
