Old 08-05-2004, 11:25 PM   #1
skatanic28
skatanic28's Avatar
skatanic28 is an unknown quantity at this point
Send a message via AIM to skatanic28
Smile zt-2 wideband installed
so i got the wideband kit with lcd display in the mail today.....and had to put it on right away of course.
im still piecing together turbo stuff so i installed it on my hotshot for now. pretty easy install, just tapped into the rpm, tps, and front o2 ecu pins and ran the o2 thru the main harness boot in the firewall.
heres a few shots of it, im still waiting to throw in an safc so things arent exactly all together yet.
controller with lcd display
ghetto mounting bracket for o2 connector = electrical tape
display w/ power in its temp hiding spot
hopefully ill have some time to play around with the datalogging tomorrow.
what do you guys think?
skatanic28 is offline   Reply With Quote
Old 08-06-2004, 02:39 AM   #2
kandyflip445
kandyflip445's Avatar
Looks nice. Did you chop the upper part of the panel that goes around the stereo and climate control?
My 240 vBgarage
Old 08-06-2004, 06:37 AM   #3
skatanic28
skatanic28's Avatar
the trim around the climate controls and vents is still there, just took the radio trim off til i got a chance to mount the display for good.
the old laptop i was tryin to datalog with doesnt like the software too much, so i might have to wait a bit more for that. the ecu really richens the mix up at WOT and high revs....i was hitting high 11's to low 12's every run.
i need a t3 donation now...free wb tuning for any takers
Old 08-06-2004, 08:11 AM   #4
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
cool good to see you made your decision that thing does look nice
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 08-06-2004, 08:21 AM   #5
crazy9ceguy
crazy9ceguy is on a distinguished road
Send a message via AIM to crazy9ceguy
how much did that unit cost?
crazy9ceguy is offline   Reply With Quote
Old 08-06-2004, 10:08 AM   #6
skatanic28
skatanic28's Avatar
its 399 with the lcd display...and 279 for just the controller w/ sensor.
this one seemed like the best for the money to me...and it has boost and egt inputs to the controller so they can show up on the display. as soon as one of you guys gives me a turbo i can show you that too.
heres the site
www.zeitronix.com
Old 08-06-2004, 10:35 AM   #7
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
Nice! Hope it helps the tuning process when you get there!
OT: what shift knob is that? is it weighted? I'm having a hard time replacing my oem knob just because I like the weight of it.
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 08-06-2004, 10:57 AM   #8
skatanic28
skatanic28's Avatar
the shift knob is from a 20th AE maxima. its not too heavy unfortunately, but it fits the threads and is a ton more comfortable than the b&m ball. you can try adding weights inside the shift boot and a couple into the knob to make the throws a bit smoother. i got it from www.progear2000.com for like 45 bucks.
