Old 05-30-2013, 09:09 AM   #1
sk8fish2012
sk8fish2012 is an unknown quantity at this point
help? my car sounds like a v8 and its bonestock?
I have a 91 hatch with a KA24DE from a 97 kouki and for some reason its been running really rough at idle and it sounds like its got bigger cams and a stroker kit in it but it just runs like crap. under load its fine but I cant find the problem, fuel pressure is alittle high, its not starving for fuel but at idle its running almost 100% lean when we checked it with a gas analyzer. MAF is clean and reading correctly the only thing I can think of is possibly the Throttle Position Sensor, any ideas?
sk8fish2012 is offline   Reply With Quote
Old 05-30-2013, 09:33 AM   #2
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
You're not firing on one cylinder.
Sounds like a boxer engine yea?
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 05-30-2013, 09:37 AM   #3
sk8fish2012
no misfires at all actually, I forgot to mention that, it sits and lopes really heavily at idle almost like its got to big of a cam in it but all the internals are bonestock
Old 05-30-2013, 10:30 AM   #4
jr_ss
Compression test? Sounds like you have a dead cylinder.
Old 05-30-2013, 10:55 AM   #5
Kingtal0n
Kingtal0n's Avatar
Naw it sounds like the IACV is stuck open letting in gobs of air, but the fuel cut is keeping the engine from injecting extra fuel so you wind up with a lope. (verify by manually adjusting the TPS such that the engine thinks the throttle valve is open some, the engine should sudden raise in RPM significantly and sound somewhat normal except high idle) Just to clarify, remove the tps and adjust it by hand while is is plugged in. Or unplug the TPS on the engine, and plug in an extra tps you have laying around.
Change the IACV it should be throwing a code.
This is what it would be on an SR20, KA I dont have much experience usually yank those out right away hehe.
tinyurl.com/4l80er
Old 05-30-2013, 01:50 PM   #6
Frank_Jaeger
Could it have jumped timing?
Frank_Jaeger is offline   Reply With Quote
Old 05-31-2013, 02:25 PM   #7
sk8fish2012
no codes, ill recheck timing when I get the chance, last time I was able to get it to 16-17 btdc and I couldn't get it any closer so ill check the chain and make sure its not jumped,
Old 05-31-2013, 02:27 PM   #8
Kingtal0n
Kingtal0n's Avatar
did you do what I suggested? it takes 3 minutes to move the tps by hand and verify the iacv is the culprit.
Otherwise, yes it could very well be the timing chain has jumped. better hope not because then the question is... why? how?
tinyurl.com/4l80er
Old 06-03-2013, 08:29 PM   #9
Zenk1_love
Zenk1_love's Avatar
Zenk1_love is an unknown quantity at this point
Headgasket? My s13 single cam did the same thing. Sounded really lopey at idle but ran like crap, although it smoothed out if I got on it. What's your exhaust look like? Any smoke?
Zenk1_love is offline   Reply With Quote
Old 06-05-2013, 12:42 PM   #10
sk8fish2012
the only "smoke" I can see is unburnt fuel, no sweet smell to it, on the hotter days it smells like a lawn mower in a way how it just smells like gas if that makes sense
