Those who have working S13 DCC please help me!!
Alright guys so I had a day off today I finally got around to installing my DCC. I bought everything together with uncut harness with all the sensors from the JDM S13. My problem is when I flip the keys for ignition on, the DCC unit wont light up/turn on.
I followed driftenthusiast's write up ( http://zilvia.net/f/tech-talk/154426...e-control.html ) but it just wont start. I referenced some other write ups as well, such as: S13 Digital Climate Control Step By Step - 240sxONE Forums S13 JDM Digital Climate Control Swap (It's easier than you think!) : 240sx General Discussion JDM S13 digital climate control write-up thread and all of them basically say the same thing. I thought well easy enough so i'd go ahead and do it. I used a test light and I am getting voltage at the red and the blue connections. I think the problem might be my ground? I did not get a reading for ground from my test light. I have attached pictures of what I did.....someone pls help!! This is my daily driver and I don't want to leave things as is. I read the write ups multiple times since last sunday and in all the write ups it said this was an easy install. |
Just find some metal bolts that are bolted to the chassis and use those for ground. You can use the bolts that bolt the shifter boot to the chassis.
^ Use one of the four bolts shown above.
Yes, extend the ground to reach.
Does the red w/blue wire receive 12V with key turned IGN. ON? Make sure it doesn't activate with key to ACC ON. Also, you are forgetting to wire up the green w/ white stripe wire (JDM side of white 6pin harness). This also must be hooked up to IGN ON.
#7 | |
Where do you suggest I connect the red/blue wire? I'm having trouble with this one. I already swapped the green w/ white stripe to the other plug so that one should be good. |
Just find a wire in the radio harness that shows 12V when you have the key to IGN ON. only. I'm not sure exactly which one, but if you have a test light you can narrow it down quickly.
So find a wire that has 12v when it is IGN on and 0v when key is out?
And the wire to ground is the red/orange stripe one am I correct? This install is giving me a massive headache. All the write ups have broken links for picture and the explanation is at many times very vague. |
#10 | |
Yes.
