Old 08-08-2004, 06:22 PM   #3
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Originally Posted by pruto
i just took out my s14 manual seatbelt two days ago. the shoulder part of the belt is held on by 2 14mm bolts and a screw (dunno what size), one on the bottom of the b-pillar behind the plastic side coverings and and one on top. The side belt part (top of the belt assembly) is attached to the existing sidebelt hole and the buckle is attached to your seat.
not exactly discriptive, but eh.
I believe the bolt head is 14mm, but the threads aren't metric and dont correspond to a 14mm bolt. They are SAE fine thread......I believe 7/16 fine thread. I put S14 belts in my S13 and had bought some longer 14mm bolts.....and the threaded part of the bolt was too thick. I took the original bolt to the hardware store and they helped me find out what it was. To run S14 belts you need a longer than stock bolt, then you can add washers and spacers behind the plastic panel and space it out correctly. I had to drill a hole in the plastic to put the bolt thru. Looks ok...works well. You'll also need to cut a slit for the belt to retract into the bottom of the panel. I can try to post pics of my setup if you want.
-m
400x200
mbmbmb23 is offline   Reply With Quote
