Old 06-21-2013, 06:07 AM   #1
mikeroy420
mikeroy420's Avatar
mikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-knownmikeroy420 is making his/her stupidity well-known
Painting a Turbo Exhaust Housing
I would like to paint my turbo exhaust housing to try and prevent rusting. I know very little about painting. Most of the high temp paint contain ceramic. The label reads bake paint for so long. I do not have the ability to bake it because the turbo is assembled. Anyone have any tips or suggests. I was thinking masking it and using bbq paint. I know its "ghetto". Again, I know very little about painting.
mikeroy420 is offline   Reply With Quote
Old 06-21-2013, 06:32 AM   #2
g_mac530
g_mac530's Avatar
g_mac530 is an unknown quantity at this point
Send a message via AIM to g_mac530
I don't know if they make a paint that can handle those kind of temps. Your best bet is ceramic coating as that can withstand temps up to 2000 degrees
Originally Posted by RoXiE.S14 View Post
Because Jesus himself made the nissan 240, true story
g_mac530 is offline   Reply With Quote
Old 06-21-2013, 07:44 AM   #3
kota2240
kota2240 is making a name for him/her selfkota2240 is making a name for him/her self
This is what i have used and it holds up great. a friend of mine has used it too.
Rust-Oleum Automotive 12-oz. Automotive High Heat Enamel Flat Black Spray Paint-248903 at The Home Depot
kota2240 is offline   Reply With Quote
Old 06-21-2013, 07:54 AM   #4
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
it does work ,if prepared correctly !!!
blessedhellrider is offline   Reply With Quote
Old 06-21-2013, 08:57 AM   #5
largekid
largekid is an unknown quantity at this point
Take it to a paint and powder coat shop and have them spray it with turbo-x or ceramakrome. $60 and its done right. And also the exhaust housing comes off the turbo so you can paint it fyi.
largekid is offline   Reply With Quote
Old 06-21-2013, 10:09 AM   #6
jr_ss
There should be about 6 bolts that hold the ex. housing to the CHRA. Remove them and carefully remove your housing. You can bake the "paint" in a house hold oven, but prepare yourself for the fumes that will ensue.
Bead blast or wire brush the housing you have. Wipe it down extremely well with acetone/lacquer thinner/wax, tar, grease removed and apply your coating once the cleaning agent evaporates.
Old 06-21-2013, 12:19 PM   #7
mikeroy420
mikeroy420's Avatar
Thanks for the response guys. Greatly appreciated.
I have been looking at this for a paint.
VHT FlameProof™ Coating
So you can separate the turbo without causing any seal damage? I have never done this and I'm kinda sketched about it.
Old 06-21-2013, 12:32 PM   #8
badbob2121
badbob2121's Avatar
badbob2121 is an unknown quantity at this point
^Yup, gaskets are pretty cool. huh?
FOLLOW ME ON INSTAGRAM = BOBBY_LS13
badbob2121 is offline   Reply With Quote
Old 06-25-2013, 10:09 PM   #9
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
If you take the turbo off you'll need to order a new turbo to manifold gasket, and a new manifold to head gasket, both of which you can get at your local dealer or from a Zilvia forum supporter like Enjuku or 240sxMotoring or similar.
Turbo to manifold is the same as the Z32 one
Manifold to head, use one from a b15 sentra with a 2.0. They have a MLS steel one much like the s15 one.
