Old 06-21-2013, 02:04 AM   #1
royale
royale's Avatar
royale is an unknown quantity at this point
Clifford 50.7X 2-way car alarm system with remote start $120
Im sure someone out there may need one of these, especially due to the increase of 240sx thefts here in LA! I picked this alarm up from s13 johny a looong while back but its just been sitting in my room. since I don't need it anymore I figured someone out there could put it to use! plus I need to purchase new tires so help me out!
includes back up battery system and glass break sensor wiring loom the 2 way and 1 way remote, also door lock actuators if your car didnt come with power door locks and any other nick nack he gave me. item is used, everything in the pictures is what you will get and is sold as is.
here are all of the features, the manual also says it has a turbo timer feature but the site says otherwise so idk.
__________________________________________________ ___________________
Protection At It's Best
Protecting your vehicle is one of the most important things that you can do. If you are going to do that, you might as well get the best protection you can. The Clifford Matrix 50.7X is one of the premier car alarm systems on the market today. Offering not only vehicle security, but also convenience. It supports 2-way paging as well as remote start. The SST remote technology can go the distance with its one mile range
Remote Start
Allows a vehicles engine to active without physical contact from the user. This feature is useful for warming up your vehicles engine and transmission to operational temperatures. In cold climates you can have your interior hot or in warm climates you can cool it down before use. All of this can be done while in the comfort of your home or office.
Rechargeable Remote
Going through batteries can end up being a costly endeavor. A rechargeable remote allows for more powerful transmitters and additional functions such as touch screen remotes and full color displays. These transmitters will remain at a consistent voltage during the discharge cycle to keep all functions working. With hundreds of recharges available, you save money on replacement batteries.
One Mile Range
Operate functions of your alarm or remote start system and receive notifications from up to a mile away. Utilize necessary vehicle functions from great distances for convenience and versatility. Forget to lock your car? Lock it from in your office, at the mall or in class. Know if your vehicle is being tampered with wherever you are.
LCD Remote
Receive visual confirmations from your vehicles security system or remote start system. Features such as remote start, lock/unlock, arm/disarm and trunk release will appear on the remote's screen with its current status. An LCD remote can display warning icons when the doors, trunk or hood are open. If your vehicle is tampered with, some remotes display what part of the vehicle was affected.
Keyless Entry
Performs lock and unlock tasks without physical contact with the vehicle. Power door locks can be controlled from several feet away or even within a building using a remote fob. The fob emits a radio frequency that is digitally encoded to prevent frequency stealing so no one can enter into your vehicle without your wireless transmitter.
Dual Zone Shock Sensor
This shock sensor utilizes warning chirps for minor disturbances and will trip the alarm if it detects more serious impacts or disruptions. Most dual zone shock sensors have adjustable sensitivity to reduce false alarms or warnings. These sensors let would-be thieves know that your vehicle is equipped with an advanced alarm system and to keep away.
Dedicated Trunk Release
This unit comes with trunk release capability and remote control integration for OEM alarm or add-on trunk release systems. Pop your trunk using your remote transmitter for convenience and ease of use. Carrying a handful of groceries? Arms tied up with luggage? Pop the trunk without using your key so it's open and waiting for you when you arrive.
2-Way Paging
Send commands to your remote start or alarm system and receive confirmation that those commands were carried out. Obtain updates on your vehicles security status and get driver pages on the remote. If your vehicle is being tampered with, your remote transmitter will warn you and set off the vehicles alarm.
Product Features:
One mile range with SST remote
Control center with integrated status LED and valet switch
2-Way LCD primary SST remote pager
Remote can confirm commands with tones, vibration, text and icon display
Remote notifies of security intrusions with tones, vibration, text and icon display
Integrated text display
Virtual Tach RPM sensing
D2D serial data interface for Xpresskit D2D serial data interface modules
XpressPort dock for Xpresskit docking serial date interface modules
Onboard flex relays for remote start and light flash
Manual transmission mode
Car Finder
Advanced remote start functions that include Timer Start, Smart Start, RunTime Reset, and more
Fail-Safe starter kill
Revenger soft-chirp six-tone neo siren
Onboard Stinger double-guard remote-adjustable shock sensor
Warn-Away technology gives a low-volume, brief warning signal for potential threats
Inputs for doors, hood and trunk monitoring
Progressive door trigger
Silent mode alarming and disarming
Ports for optional tilt, glass break, cabin and proximity sensors
Keyless entry with optional progressive driver's unlocking and ignition-controlled locking
Trunk release
Product Specifications:
Priority 5-button user interface with easy dual car operation
Slim 5-button SST 1-Way companion remote control
One Mile Range with SST
Priority user interface and icon map
Powerful lithium-ion rechargeable battery with mini-USB charging
Active temp check displays internal cabin temp while remote start engaged
SilentMode2 alerts of intrusions without vehicle siren or light activation
3 auxiliary outputs
1-year SonicElectronix.com warranty
Also found as: matrix-507X
General Features
Car Alarm Yes
Remote Start Yes
Keyless Entry Yes
2-way Paging Yes
Number of Remotes 2
Number of Buttons on Primary Remote 2
Main Transmitter Type LCD
Sidekick Remote Transmitter TypeButton(s)-only
LED/Display Color Black
Number of Vehicles Supported 2
Number of Auxiliary Outputs 3
PC Programmable No
Convenient Features
Panic Mode Yes
Trunk Release Yes
Valet Mode Yes
Alarm Features
Paging Range 1 Mile
Siren Yes
Shock Sensor Dual Zone Shock Sensor
Two-Way Paging Features
Transmitter Alert Audible
Vibration
Interior Thermometer Yes
Remote Start Features
Cold Start Timer Yes
Turbo Timer ?
Compatible with Diesel Engines No
Engine Start Intervals Yes
royale is offline   Reply With Quote
Old 06-25-2013, 06:38 PM   #2
royale
royale's Avatar
tuesday bump
Old 06-25-2013, 10:09 PM   #3
ehp
ehp is an unknown quantity at this point
mabye im blind but is it new or used? wasnt really clear to me
Edit: NVM I SAW IT. it is used. hmmmmm mabye. considering getting it.
ehp is offline   Reply With Quote
Old 06-25-2013, 10:56 PM   #4
royale
royale's Avatar
lol Yes its used. if you do decide to pick this up let me know. I'll answer any question or concern to the best of my knowledge.
Old 06-25-2013, 11:16 PM   #5
Gamma
Gamma is an unknown quantity at this point
where u located might pick thiss up
Posted from Zilvia.net App for Android
The answer is in the math. HP = (TQxRPM)/5252
Gamma is offline   Reply With Quote
Old 06-25-2013, 11:21 PM   #6
royale
royale's Avatar
I am located in Downtown LA, if interested pm me for more info.
Old 07-23-2013, 10:31 PM   #7
royale
royale's Avatar
sold!!!!!!!!
2-way, car alarm
