![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Painting a Turbo Exhaust Housing
I would like to paint my turbo exhaust housing to try and prevent rusting. I know very little about painting. Most of the high temp paint contain ceramic. The label reads bake paint for so long. I do not have the ability to bake it because the turbo is assembled. Anyone have any tips or suggests. I was thinking masking it and using bbq paint. I know its "ghetto". Again, I know very little about painting.
This is what i have used and it holds up great. a friend of mine has used it too.
Rust-Oleum Automotive 12-oz. Automotive High Heat Enamel Flat Black Spray Paint-248903 at The Home Depot |
#4 | |
![]() Join Date: Jan 2012
Take it to a paint and powder coat shop and have them spray it with turbo-x or ceramakrome. $60 and its done right. And also the exhaust housing comes off the turbo so you can paint it fyi.
There should be about 6 bolts that hold the ex. housing to the CHRA. Remove them and carefully remove your housing. You can bake the "paint" in a house hold oven, but prepare yourself for the fumes that will ensue.
Bead blast or wire brush the housing you have. Wipe it down extremely well with acetone/lacquer thinner/wax, tar, grease removed and apply your coating once the cleaning agent evaporates.
Thanks for the response guys. Greatly appreciated.
I have been looking at this for a paint. VHT FlameProof™ Coating So you can separate the turbo without causing any seal damage? I have never done this and I'm kinda sketched about it. |
#9 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Turbo to manifold is the same as the Z32 one Manifold to head, use one from a b15 sentra with a 2.0. They have a MLS steel one much like the s15 one.
