Old 08-12-2004, 11:19 AM   #1
AutoRnD
AutoRnD's Avatar
AutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the roughAutoRnD is a jewel in the rough
Send a message via AIM to AutoRnD
5 lug hub's anyone try?
ok.. now call me stupid.. but what if you press out your old front and rear hubs.. buy new bearings and just buy the nissan 5 lug hubs and press those in.. would it work? or am i just smoking crack.
www.AutoRnD.com
Nardi, Enkei, Stance, AME Master Distributors for USA
Check Out Our Facebook!
AutoRnD is offline   Reply With Quote
Old 08-12-2004, 11:23 AM   #2
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
Stupid! haha seriously... umm what? Im not following your questioning? S14 SE front hubs the bearings and stuff are non replaceable, you'll get them with the hub.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 08-12-2004, 11:55 AM   #3
projectRDM
projectRDM's Avatar
In the rear you can do that. The front S14 hubs are not rebuildable.
FORMERLY R240NA
Old 08-12-2004, 12:04 PM   #4
Powashiftin
Powashiftin is an unknown quantity at this point
When i got my front five lug hubs, one was ABS one was NON ABS... i swapped out the middle bearing off of a four lugger ABS into a five lugger NON ABS. It worked for me.
http://www.tempusband.com
Powashiftin is offline   Reply With Quote
Old 08-12-2004, 04:10 PM   #5
doogie240
doogie240 is an unknown quantity at this point
I replaced nothing but my front hubs on my old s14 with used ones from a SE S14...no problem...Rear I replaced the entire knuckle...If you can, I'd try doing it this way
doogie240 is offline   Reply With Quote
Old 08-12-2004, 04:37 PM   #6
projectRDM
projectRDM's Avatar
Why did you switch it out? ABS hubs are the exact same as non-ABS, they just have a sensor ring on the backside. Unless you have ABS.
You can do that, but it will eventually fail, the S14 hub was designed specifically to not have a replaceable bearing due to cost. There's no gaurantee that it will seat properly and stay seated over time.
FORMERLY R240NA
Old 08-12-2004, 04:39 PM   #7
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
Nissan wont sell just the front hub without the bearings....the hub only comes with bearings pressed in....but im sure u can find some bearing company that would sell u some bearings...
the rear Z32 hub/bearings, however are replaceable, and cost $$$$$$$$$
Heartwork is offline   Reply With Quote
Old 08-13-2004, 12:15 AM   #8
Powashiftin
As I said, I bought a 5 lug NON ABS hub. My car has ABS. I swapped the ABS ring and bearing from my 4 Lug hub into the NON ABS hub. Unless the shop just swapped the ABS for NON ABS rings, im 99% sure the ring is a part of the bearing and that they swapped the bearings.
Who said that the S14 hub was designed specifically to not have a replaceable bearing due to cost?
Old 08-13-2004, 04:05 AM   #9
projectRDM
projectRDM's Avatar
Nissan said that. Their parts fiche does not show a separate bearing for the S14 front hub. The S13 front hub is replaceable and available separately.
Sorry for the confusion on the ABS, your post didn't specify whether you had it.
FORMERLY R240NA
