Old 07-12-2013, 09:12 AM   #27
marks14
marks14 is an unknown quantity at this point
Are you bleeding the system this way?
Two people. Person A and person B.
Person A....
Open door
sit in seat
when told, push foot brake down steadily and hold it down.
then, with foot brake down, steadily pull handbrake and hold it there.
when told, release the handbrake, and then the footbrake.
Relax.
Repeat when told.
Person B
Lay on floor, open rear driver's side caliper bleed screw.
Tell person A to push the pedal, then pull handbrake.
When they are holding both brake devices, tighten the bleed screw.
Tell person A to release the brake devices.
When person A has released them, loosen the bleed screw again and tell person A to operate the devices again.
Repeat this process a few times until the fluid spurts out a nice solid stream of fluid, not pissing, no bubbles, no spitting. Clamp bleed screw and move to rear passengers's side. Repeat the process.
marks14 is offline   Reply With Quote
