![]() Join Date: Sep 2009
![]() Feedback Score: 10 reviews
if its cranking and it runs that means u have fuel air and spark . but im betting that ur distributor ,cap,and rotor needs to be replaced and makye ur timing is off u should really test theese things before u spend money on stuff u dont even need
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
It could be a bad ignition switch. I have seen it where if you crank the key all the way it will crank fine, but not fire. If you just turn the key barely enough to crank, it starts fine. Try turning the key more carefully and see if that makes a difference. This issue would be worse hot as well...
#3 | |
I also checked at turning the key different and that didnt help. |
