Old 08-17-2013, 05:31 PM   #1
PIN GIO 2
PIN GIO 2's Avatar
PIN GIO 2 is an unknown quantity at this point
Send a message via AIM to PIN GIO 2
LS1 Engine and T-56
I really hate post it for sale because i spent money on engine too much! i have to sell it due cant afford build 240sx drift track project. So i need to back to school and no time build this car. CPR is the one who build my engine port cnc 853 head cylinders with aluminum 5.3 block from 2007 silverado truck low miles. new beehive valve springs, new isky big camshaft, new camshaft Clevite bearing, new rod Clevite bearing, new crankshaft Clevite bearing, balanced ls1 crankshaft had 24x crank, new piston rings, new ls2 lifter, new ls2 timing chain, new katech rod bolts, new Melling oil pump, new gto oil pan with improved racing oil pan baffle and come with Oil Accsump, stainless steel lines, Oil Cooler Adapter and Oil Cooler brand new in box, make custom standalone engine harness with PCM tuning by CPR, i found low miles T-56 i was paid $1800 for it, come with new solid mount. you will have to get new clutch kit but i have flywheel. of course i will throw firebird ls1 accessory drive included. new water pump from c5. New rebuild ps pump, ls1 starter, 02 sensors front pair, new belts, ls1 intake maniold, new gasket kit, new head gasket, oh block have been deleted D.O.D. underneath block off and come with ls2 valley cover. pretty much enough info and i may forget add more. if u plan to ls1 swap into 240sx then i will give you my front subframe modified clearance gto oil pan and motor/trans mounts. sikky drive shaft. You will need buy egr block off and new clutch kits and clutch slave. also i have radiator and elec fans for sale as well.
i havent start it up so still zero mile fresh engine. i really sad to see it sell. im interesting in trade car or $6700 cash. text me 8 zero 5 551 57 five seven
trade car:
rx7 fd shell
e30
240sx s13 or s14
s15 shell
supra shell
look for rwd must be 5 speed
proof Anthony did build this CPR engine
PIN GIO 2 is offline   Reply With Quote
