Old 09-12-2013, 01:14 PM   #1
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Oh wow, that was significantly different than expected.
Check your tire to fender clearances, and see if they're making contact (though you would see wear with the amount of noise it's making).
It almost sounds like a bushing, have you recently changed your ride height without correcting the bushing loading? Also, check to make sure that all of the bushings are properly torqued and not staying stationary while the suspension is moving. Grease all of your aftermarket heims, and any poly bushings too.
thefro526 is offline   Reply With Quote
Old 09-12-2013, 01:25 PM   #2
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
check the top mount of the shock.
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
