Old 09-08-2013, 09:51 PM   #1
Driven08
Trader Rating: (354)
Driven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfection
Feedback Score: 354 reviews
Talking WTT/WTS:240sx Hatch,Kouki Aero,Sr20,Suspension,AME,5lug,Brakes,Diff,Cage,PBM ,Greddy
PLEASE READ
1989 Nissan 240sx Hatch. Power windows, locks, mirrors. Keyless entry via alarm remote. Has Heat but no a/c. NO rust or frame damage.
This car has been great to me in every way. It gets tons of compliments everywhere I go whether it’s at the stop light, parking lot, drive thru, car meet etc. This car even won 3rd place for Formula D Long Beach 2013 "drift" class from Slammed Society/Fatlace. Its main purpose was to be a daily driver but also see the track. It has full interior with the Safety21 6 point cage, it’s quiet and super reliable. I daily drove it for 3 years straight without any major issues. The only thing that was a problem was the CAS so I replaced it with a brand new one from Nissan. This is why you’ll see I have bought many new parts from Nissan, that reason is to keep it reliable.
I did 1 drift event for a few hours to see the fruits of my labor and I can now say I’m 100% satisfied that it lived up to what it was built for. It handled great without issues, ran cool as always, ran strong and didn’t miss a beat. I even drove it there and back. The reason why I want to sell my pride and joy is because after all the long hours of searching, picking up parts or tinkering with it, I have come to the conclusion that I want to move on. Sadly, it sits in my garage when not being driven(which is 2-4 times a month) so if someone else could put it to good use, it would be a great car to have. I do not need to sell it, but if it goes, it goes. I’m trying to set myself free of any money pits that I have and set myself up to make a home purchase sometime next year.
The Bad: It does hold a salvage title from a parking lot accident that occurred in 2003(2003 or 2004) but it was only a fender that was replaced, NO FRAME or structural damage. Potential buyers can come inspect it and we can pull the fenders off if you’re a SERIOUS BUYER. PLEASE don't cry about this and use it as a bargaining card. I will simply ignore you. It could use a new alignment as well.
This is a turn key car ready to hit the streets, tracks or meets. No need to worry about all the hours your wife/girlfriend/boyfriend, husband or combination of those will nag at you for working on a car. Just add gas, and go wherever you please.
PRICE:SOLD SOLD SOLD
*New parts have under 7k Miles and 1 drift event.
Engine/Performance:
S13 SR20det Red Top
Only ran Mobil 1Full Synthetic 10w30
Mildly tucked Harness
Brand New CAS
Brand New TPS
Brand New IACV
Brand New Fan Shroud
Brand New Gates Micro V Belts
Brand New Black Silicone Hoses
Brand New Coolant Overflow Tank
Brand New OEM timing Chain Tensioner
Brand New S14 SR Water pump
Brand New Walbro 255lph Fuel Pump
Brand New Fuel Filter
Greddy 52mm Black Electric Oil Pressure Gauge
Greddy 52mm Black Electric Water Temp Gauge
Greddy 52mm Black Electric Boost Gauge
Greddy 2 Row Radiator(Runs 158F all day)
AEM Digital Wideband
Nismo Thermostat
Nismo Type-A FPR w/ Marshall Liquid filled gauge
New fuel lines
Brand New Custom SS Power Steering line. Similar to Chase Bays line.
S13.4 Hybrid Valve Cover done by Bardabe Performance
7 layer S15 Exh. Manifold gasket
New S15 Spec-R Garrett T28
HKS Wastegate Actuator
HKS 264/264 Step 1 Cams
Earls SS Oil and Coolant lines
ARC BOV
Greddy FMIC
Nismo 740cc Injectors
N62 Maf
New OEM Mazda Miata Battery
RS-Enthalpy Tuned Ecu(264/264,S15 T28,740cc,14psi, 255 walbro, etc)
Apex'i Filter
Tomei Intake Adapter
Powered By Max Flex Cobra Downpipe
Catco 3" high flow cat
Kakimoto Cat Back(cut and welded to sit higher)
Circuit Sport Poly Exhaust Bushings
DIF SS Fire Sleeved Clutch line
New OEM Slave cylinder
6 Puck Clutch
PBM Magnetic drain plug
Circuit Sport short Shifter
New OEM shifter bushing
Suspension:
Powered By Max Coilovers
Powered By Max Angle spacers
Custom Tig welded LCA’S: Consist of Notched(More angle) Boxed, Extended 20mm,QA1 Misalignment bearings and Energy Bushings. 40mm Roll center correction(adjustable by switching out spacer between knuckle and lca)
Custom Cut knuckles by D.Adams on here. 15mm Bump steer correction and gusseted.
New Outer CV boots
SPL Version 1 Toe Rod's
SPL Version 1 Traction Rod's
SPL outer Tie Rod ends(bump steer correction)
Kazama RUCA's
Driven08 Eccentric Lockout Kit
Tein Inner Tie Rod's
Nismo 2 way LSD
JDM Diff w/ 5 bolt axels and diff cover
Circuit Sport Tension Rods
Johnny Fraz Tension Rod Brace(Like Nismo Brace)
Energy Suspension Front Sway bar bushings/endlinks
Energy Suspension rack & pinion bushings
Z32 Rear 5 Lug Hubs
Aftermarket 5 Lug Front hubs
Brakes:
Z32 30mm Front Calipers w/ss lines & slotted rotors
Z32 Rear Brakes with working Ebrake w/ ss lines, new pads & slotted rotors
Z32 Rear Ebrake Assembly w/ powdercoated black backing plates
Project Mu Ebrake shoes
Brand New Z32 1” BMC
Brand New Ebrake Cables
Driven08 Z32 2+2 Ebrake cable bracket
Wheels/Tires:
AME Tracer TM-02 Polished Finish(I had fronts re-done and rears were done by a previous owner)
Front: 18x9.5 +22 w/ 7mm Powered By Max Spacer and Nankang 225/35 NS-II(3k miles if that)
Rear: 18x10 +15 Federal 235/40(Lots of life)
Exterior:
Mercedes Black Single Stage Paint(6/12/12)
Kouki OEM Bumper(Purchased New)
Kouki OEM Turn Signals(Purchased New)
Kouki OEM Position Lights(Purchased New)
Kouki OEM Extensions(Purchased New)
Kouki OEM Extension Brackets(Purchased New)
Kouki OEM Sideskirts
Kouki OEM Valences
Kouki FPR Center Valence
Kouki FPR OEM Style Spoiler
Kouki FPR OEM Style Lip (super flexible and strong)
Kouki OEM Tail lights
Raybrig H4 Housing Headlights
6k HID’s
M3 Clear Sidemarkers w/ leds’s
Interior:
Clean Black Dash
Safety 21 6 Point Cage
Nardi Deep Corn 350mm
NRG Short Hub
NRG QR
Bride Zeta III w/ Gradation
Bride FG Sidemount rails
S14 Passenger seat
Dyed black rear seats
Black wrapped glove box
Full Interior
S14 Manuel Seat Belts
Nismo Shift Knob
Working Digital Climate Control
DOHC Cluster w/ SR RPM
All green interior gauge lighting(Cluster,Headunit,Gauges,DCC)
New JVC Headunit w/ Aux, USB, color change,etc
Pioneer Speakers
Newish Turn Signal and Wiper Stalk
Leather Shift boot
Center Gauge Pod w/ Greddy Gauges
Now onto the pics. Courtesy of Limit Photo. Check them out at www.facebook.com/limitphoto
Interior:
Bay:
(Greddy rad and Nismo fpr are now polished)
Suspension/Brakes:
Excuse the CS Bolts. I can replace upon request
Driven08 is offline   Reply With Quote
Old 09-09-2013, 01:22 AM   #2
SMITHZAC000
SMITHZAC000 is an unknown quantity at this point
Your 240 is just beautiful. The only way it could possibly be better is if it was a Rocket Bunny
SMITHZAC000 is offline   Reply With Quote
Old 09-09-2013, 05:43 AM   #3
maces13
maces13's Avatar
maces13 is an unknown quantity at this point
Beautiful car bro. I can see why the price is that amount, this thing is flawless. Even the sr looks clean with all the right parts, looks like it just left the showroom floor really. Drives like a dream i bet GLWS
maces13 is offline   Reply With Quote
Old 09-09-2013, 07:24 AM   #4
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
This car is so rad, wish mine was this cool GLWS!
hobbs is offline   Reply With Quote
Old 09-09-2013, 10:00 AM   #5
D.Adams
D.Adams's Avatar
D.Adams is an unknown quantity at this point
Send a message via AIM to D.Adams Send a message via MSN to D.Adams
I hate you ... Hit me up its been a while think I lost your number
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Owner of NVS Fabrications
D.Adams is offline   Reply With Quote
Old 09-13-2013, 05:10 PM   #6
Driven08
Thank you for the comment but I don't like rocket bunny. Not a fan of frp bumpers
It ls a blast to drive. Thank you
Your cars just as rad!
Message sent
Old 09-13-2013, 07:46 PM   #7
240sx guy
240sx guy is an unknown quantity at this point
Wow is all I gotta say....u my friend have great taste, and deep pockets too haha
240sx guy is offline   Reply With Quote
Old 09-13-2013, 07:55 PM   #8
baogzhlia
baogzhlia is an unknown quantity at this point
I'll still look for the site I saw em on
baogzhlia is offline   Reply With Quote
Old 09-13-2013, 08:46 PM   #9
xilovelsdx
xilovelsdx's Avatar
xilovelsdx is on a distinguished road
Send a message via AIM to xilovelsdx
Honestly a great price for what you get. Sick car man.
xilovelsdx is offline   Reply With Quote
Old 09-19-2013, 07:35 PM   #10
Driven08
This took a few years to get to where its at. It was a long road but worth it.
You sir speak the truth
Old 09-19-2013, 09:44 PM   #11
Konster
Konster's Avatar
Konster is an unknown quantity at this point
Great price for a great looking vehicle.
Hyer.
Konster is offline   Reply With Quote
Old 09-20-2013, 06:34 AM   #12
slow_sr20
slow_sr20's Avatar
slow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant future
your price is too low. This is a hell of a car. Bump for you.
slow_sr20 is offline   Reply With Quote
Old 09-20-2013, 08:32 AM   #13
Trace
Trace is an unknown quantity at this point
this should be in a showroom at a nissan dealership
Trace is offline   Reply With Quote
Old 09-20-2013, 08:48 AM   #14
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
s13 kouki will always be ageless timeless piece
bump for a fellow kouki owner
Old 09-22-2013, 06:00 PM   #15
Driven08
Thank you all for the positive comments.
Old 09-22-2013, 08:07 PM   #16
supra_speed
supra_speed's Avatar
supra_speed is a well-known jackass
very clean car id consider a trade if you have copies and photos of insurance report showing the damage
supra_speed is offline   Reply With Quote
Old 09-22-2013, 09:43 PM   #17
stevefitter281
stevefitter281 is an unknown quantity at this point
Clean as effff!!! Beautiful car!
stevefitter281 is offline   Reply With Quote
Old 09-22-2013, 10:30 PM   #18
tdaffern
tdaffern's Avatar
tdaffern is an unknown quantity at this point
Bump for a boss AF car and for a legit guy to buy from. His feedback speaks for it's self.
My build
Check out West Motors for all your automotive needs https://www.facebook.com/WestMotorsAz
tdaffern is offline   Reply With Quote
Old 10-03-2013, 11:31 PM   #19
Driven08
Only looking for IS300 as partial trade at this moment.
Thank you
Feedback does say something these days. I hope you finish your car btw.
Old 10-10-2013, 05:14 PM   #20
jsyoo0103
jsyoo0103's Avatar
jsyoo0103 is an unknown quantity at this point
When did this get sold?
jsyoo0103 is offline   Reply With Quote
Old 10-10-2013, 06:33 PM   #21
SecretS13
SecretS13's Avatar
SecretS13 is an unknown quantity at this point
Curious how much it sold for if u don't mind
SecretS13 is offline   Reply With Quote
Old 10-10-2013, 06:35 PM   #22
jsyoo0103
jsyoo0103's Avatar
I remember it was like $13,000
