![]() Join Date: Dec 2011
S14 sr20det koni greddy aem z32 brakes 300zx turbo garrett
Please read listing for updates. Prices are listed so please don't ask what I want for them. You can make a reasonable offer though. If it is not listed then I don't have it however I may find more parts later down the line. Please text/call me on my cell at 3one074077one6. These prices are NOT shipped unless we work a deal.
Engine parts: $3600 S14 sr20det NA ecu, Wiring solutions Upper and Lower harness for s14 NA ECU into s13 chassis, ACT streetlight flywheel, and stage 1 clutch, Nismo thermostat, Circuit sports engine pullys, alt and ps pump, 8mo old water pump and Nismo thermostat, factory NA ecu, igniter, maf and FR sport inline fuel pressure gauge, S15 turbo Garrett (very lightly used maybe 1k miles if that much) W/SS lines(new). It will need to be reclocked. I will explain if interested) has not been installed on to motor, 97 g20 throttle body. $400 Factory gasket kit minus v/c gasket NEW, Factory timing chain kit NEW, Factory Oil pump NEW Suspension Parts: $60 Circuit sports tension rods. Electronic parts: $1750 Aem 30-6600 standalone with patch harness pre wired with AEM map, o2, iat, Factory clutch switch (W/sensors and gauges) and MAC EBC not wired in yet. Exhaust Parts $100 greddy down pipe. Has scratches and a slight dent. Its small so I cant imagine that it really affects performance much if at all and Megan 3in test pipe $60 New ps rack in the last year with new outer tie rods lines and resavor $100 Greddy turbo outlet pipe/ o2 housing NEW Brake Parts $300 300xz brakes front calipers DIF SS lines and rotors. Iron calipers. $300 300zx brakes Rear dif ss lines (w/parking brake cables, backing plates, and components included) Aluminum calipers. Drivetrain Parts: $300 Ichiba Hubs FT and RR w/extended arp speed tip studs 20 19mm aluminum lug nuts, extra spare studs. $600 S15 Torsen HLSD with flanges. New side bearing were installed when installed into my car. About 5k on the bearings. Also comes with new pinion seal and new bearing. Interior Parts: $40 duel gauge pod mounted on steering column clam shell. Comes with upper and lower parts of clam shell. $20 Sun visor aftermarket $50 Autometer 3 gauge a pillar pod $40 Both manual window regulators with cranks Jared Last edited by Jfornachon; 01-20-2014 at 01:00 AM.. Reason: Removed sold items and added one as well. |
