#20 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
The shift boot idea is ridiculous. If the tension on the shifter from the shift boot being installed incorrectly causes your trans to pop-out then there is something wrong with your trans. I've seen a million shift boots backwards and not one of them popped out of gear. Installing the clutch and/or throwout bearing incorrectly would also not cause popping out. That would also cause funny shifting/grinding alone. Make sure that the bushing on the tip of your shifter is installed. I have seen those missing before and that could cause the trans to not go completely into gear, which would cause it to pop-out. Other than that there is NOTHING external to the transmission that would cause it to pop-out. It could be worn shift linkage internal to the trans, but you would have to tear the trans completely apart to fix that. It could be in the synchros, gears, or blocking rings. BUT those issues would require a full rebuild as well. You're clutching at straws here, the problem is inside the transmision. |
