Old 10-02-2013, 08:06 PM   #1
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^You guys got an alignment done? If yes, have you double checked to make sure you dont have anything bent?
CLICK HERE!!!
Old 10-02-2013, 09:02 PM   #2
Boosted92
Boosted92's Avatar
Boosted92 is an unknown quantity at this point
I didn't have the alignment done, the PO did - but I looked at the sheet and it's all good. I took a good look at the car underneath and everything is straight and it's got a clean Carfax (which really doesn't mean much). Reading these forums it just seems common for one wheel to stick out more than the other, but those ~11mm really bug me.
2006 Holden Monaro - 700+whp ; 2014 Holden Commodore SSV - 400whp
Boosted92 is offline   Reply With Quote
Old 10-15-2013, 07:30 PM   #3
fliprayzin240sx
But the kicker for you is that its common on older S13 chassis but not on S14s. Most of the time, when its shifted that far out, something is messed up. It could be mismatched lower control arms (one is a shorter S13 replacement), subframe is shifted or the frame is bent.
CLICK HERE!!!
Old 10-15-2013, 07:36 PM   #4
Jav
Jav is an unknown quantity at this point
I actually have the same problem with my rear. The driver side sticks out about ~10mm more than the passenger. I have adjustable RLCA, Toe rods, and Traction rods, and my frame is also straight. But.. flip could be right about a shifted subframe or bent frame but I can't seem to find the reason why there's this difference on my s13. It also bugs me
Jav is offline   Reply With Quote
