#31 |
you should try swapping to a better pad before you throw money at a whole new braking system.
you should also include what your current pad selection is and also what tires you are running. are you overheating your brakes or are you locking it at the end of the drag strip |
#32 | ||
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
I would also recommend REAL brake ducts rather than the stupid deflectors though. Like so: ![]() ![]() ![]() ![]() This is important. The BEST setup for pedal feel and response that I found for the Sumitomo calipers was the Z/auto dual diaphragm booster with the 1" master. If you run the 17/16 master with the dual diaphragm booster the brakes are very touchy. With the small booster the pedal just feels too hard and unresponsive to me. |
#33 | ||
"Real" brake ducts are nice for a track only car, but not always necessary/needed on a "street" car. I think for a street driver car they are a bit much, you'll never get your brakes up to the temperatures to justify installing something like that. The deflectors are just a added benefit, which can still cool the inside of the rotors too much. Quote:
#34 | |||
#35 | |
![]() Join Date: May 2008
i'm running the 17/16 MBC on an S13 auto booster with my brembo calipers, and it is retarted stopping power. very VERY VERY touchy.
#36 | |
![]() Join Date: Jun 2003
The 240sx vs. Civic thing is purely based on market. There are a lot of guys that race Civics. Racers look for quality parts with cheap wear part replacement costs. 240s, on the other hand are primarily drift cars, fewer of them to begin with, and JDM fan boys would rather buy a Rotora kit than a kit that is cheaper to buy and maintain. I still think you have an issue with either fluid or pad condition, or brake balance. The only way you should be able to fade big brakes in a single stop is if something is wrong. For reference, what speeds are we talking about at the drag strip, 120-20 mph stop? While track time will be harder on the brakes on average, you won't be slowing down as much for each corner with time to cool the brakes in between stops. Thanks for the reminder why I don't post here much anymore. We aren't trolling anyone, just stating facts. Yes, bigger brakes will help with fade, but thinking about a problem instead of throwing money at it with no guarantee of fixing it is the smart thing to do. Feel free to keep filling this forum with mindless junk. I'm out.
#37 |
That's exactly my point. If you switched to the 1" master you would have the same stopping power the pedal would just be less touchy and easier to modulate. That is good, not bad. You need to be able to modulate the pedal to brake at the limit without the help of ABS. Touchy brakes lock-up easily, which is a large concern in any driving environment.
#38 |
Feelings hurt lol.. Then don't post here any more. Again op car sounds like it makes to much power for the shit improvised brakes you have on the car up grade to some thing bigger simple as that.
#39 | |
His car weighs at most 3500lbs with him in it. Do you think the 370Z needs six pots? How about the ridiculously heavy Mustang GT and Camaro SS, do they need them? They don't run them from the factory, I suppose the engineers that designed those cars don't know what they are doing. 6pots fix everything...
#40 | ||||
![]() Join Date: Dec 2004
Trader Rating: (58)
If we can run 140 out the back door on ford single piston calipers on different shitboxes from the 80's and stop before the sand, I would tend to think you've got the wrong pad compound on the car. Quote:
