Old 11-11-2013, 08:59 PM   #1
biggieB15z33
biggieB15z33 is an unknown quantity at this point
Brake pedal pulsating need help!!!
Ok I did an sr20det swap on my vert and when I apply the brakes and I keep them pressed and rev the engine the brake pedal pulsate/moves up and down, when I rev the engine the brake pedal pushes my foot upwards and when I stop reving the brake pedal returns to the original position, all this is while the car is parked, I didnt have any problems when I had my KA swap,any ideas or solutions????
biggieB15z33 is offline   Reply With Quote
Old 11-11-2013, 09:37 PM   #2
mechanicalmoron
The brakes are vaccum assisted.
When you rev, vaccum drops, and there is less assist.
Old 11-12-2013, 08:21 AM   #3
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
Make sure the check valve is in the brake booster hose.
OnTheChip is offline   Reply With Quote
Old 11-12-2013, 09:38 AM   #4
biggieB15z33
I checked and the hose is connected to the check valve bro
Old 11-12-2013, 10:01 AM   #5
mechanicalmoron
You can blow in the check valve to make sure it functions. (obously, it should blow towards the manifold, and not towards the booster)
But yeah.... my KA does it. Any car with vaccum assisted brakes will do it. Maybe you're feeling it more strongly because there really is no vaccum if you're revving into boost. And if the check valve doesn't work right, you could be forcing boost into the booster, and actually having the assist fight you instead of help. At least, that's my understanding of it.
