Old 11-05-2013, 10:42 AM   #1
lilnev11
lilnev11 is an unknown quantity at this point
SR20 surging issues bugging the Eff out of me
To no helpful prevail I did try the search bar but couldn't find any one with similar problems as me.
So, I just traded my bike for an s14 with a blacktop SR. I'm kinda familiar with boost but by no means any kind of expert. here goes it. It will surge pretty often if I'm in the range of -10in to about 3-4psi I snap off the throttle I'll get some hefty surging. The TurboXS BOV that's on it right now will wiggle on the flange but still blows off as it should. I don't think there's any kind of leaks all though the signs are there. It'll idle between 1200-1600 after warming up. builds boost fine all the way up to 12psi. I tried spraying brake clean at any possible leak points & had no change in the idle. What im most confused by is why it's surging under vacuum.
lilnev11 is offline   Reply With Quote
Old 11-05-2013, 11:27 AM   #2
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
What exactly is your definition of "surge"? 1200rpm is too high for an idle unless you have cams or some reason to be so high. Should be 750-800.
blkvrtswp is offline   Reply With Quote
Old 11-05-2013, 11:38 AM   #3
lilnev11
I don't know why my idle's so high I was figuring that could be playing a factor. compressor surge or the bark. chakukukuk when throttle plate shuts & boost isn't vented. I softened the spring a bit but that doesn't answer my question as to the vacuum.
I've come to you guys for help. Yes i'm new to the site. Please keep the bashing to a minimum hahaha I just want my car to run right & ive read on previous post some guys on here can be pretty ruthless.
Old 11-05-2013, 07:38 PM   #4
blkvrtswp
blkvrtswp's Avatar
Some BOVs make the chuka chuka sound, try tightening the spring too. The sound may change. Watch some youtube videos of other SRs to see what they sound like.
On a stock SR turbo with a BOV, "compressor surge" is nothing to be concerned about. Just make sure your BOV is actually working and the vac line is connected to the correct place and enjoy the noises!
Old 11-05-2013, 09:22 PM   #5
lilnev11
I've tried tightening & loosening the spring tonight. Not much change. I'm 100% it's surge cause I can snap the throttle from under the hood and hear it straight from the turbo. There also seems to be a bit of delay between closing throttle and the bov relieving pressure. But would that still relate my problems under vacuum?
Old 11-05-2013, 09:27 PM   #6
lilnev11
& I've heard that go both ways. Some say the surging doesn't effect the turbo some say its detrimental. Personally I think stopping a ball bearing turbo mid free spin isn't good. And yes it is a t28r
Old 11-06-2013, 05:44 AM   #7
JF_OverBoosted
JF_OverBoosted's Avatar
JF_OverBoosted is an unknown quantity at this point
Is it adjustable? If it is try loosening it.
if not possibly just a bad BOV?
goodluck!
JF_OverBoosted is offline   Reply With Quote
Old 11-09-2013, 05:39 PM   #8
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
double check the vacuum diagram. make sure youre on the correct tb nipple
RedtopTech is offline   Reply With Quote
Old 11-09-2013, 06:26 PM   #9
ultimateirving
ultimateirving's Avatar
It's the iacv. Take off ur manifold and remove the iacv. Clean it thoroughly. And reset the idle properly
Z32 with lq4 swap
Old 11-09-2013, 07:11 PM   #10
DJ 21o3
DJ 21o3 is an unknown quantity at this point
Check the vacuum lines first. That was the issue my car had but it is now fixed. It blows off fine with enough boost but under 5psi, i still get surge.
DJ 21o3 is offline   Reply With Quote
Old 11-09-2013, 08:24 PM   #11
Drifter_85
Drifter_85 is an unknown quantity at this point
I'm having the same problem. The setup on my car didn't even have a bov so I installed one. If the spring is loose it works perfect but after the engine warms up it will fluctuate but if I tighten the spring idle goes back to normal but with it tight it will surge at low boost or even no boost and at a little higher boost it will surge for a second before the bov opens but on full boost no surge at all. I kinda like it so I don't worry about it
Drifter_85 is offline   Reply With Quote
Old 11-10-2013, 09:01 AM   #12
Ka-t in progress
Ka-t in progress is an unknown quantity at this point
Where is your bov mounted? After the maf or before?
Ka-t in progress is offline   Reply With Quote
Old 11-10-2013, 09:57 AM   #13
Drifter_85
My maf is on the intake to the turbo. In stock location
Old 11-10-2013, 02:46 PM   #14
Ka-t in progress
But where is your bov mounted at? Is it after the maf or before it. Trying to see if it is a recirc set up or draw thru
Old 11-10-2013, 03:33 PM   #15
cotbu
cotbu's Avatar
Clueless much? If the bov fluctuates, there's a vacuum leak, this could even be seen in the tachometer. Although the vacuum fluxing at idle and rpm bouncing could be from cts, etc. So you have to eliminate things, Do a vacuum boost leak test, pull codes, check timing etc. Recirculating the bov will hide this issue, but won't cause big issues, if you allow the controlled leak to occur. Unless the leak is big or fluctuation is caused by cts, a faulty cts, can fail on its own either sensing overcool, or overheat. Wiring or even be disconnected. This post could get long just describing the possible symptoms, so ill stop.
Do you have iacv coolant lines hooked up?
It could be numerous things, goodluck though
Sent from my Highly Tune Galaxy S3.4!!!
Old 11-14-2013, 06:13 AM   #16
steve shadows
steve shadows's Avatar
I suggest checking timing with a timing light before anything else. If timing is off it will feel like there is little power then a lot all of a sudden when there shouldn't be any lag etc.
Like Me on FaceBook !
