Old 11-19-2013, 12:30 PM   #1
Djmorfintime
Djmorfintime's Avatar
Djmorfintime is an unknown quantity at this point
ka 240sx in need of help cooling problem
ok soo I have my 91 240sx ka and It was overheating said the temp gauge on my cluster so I pulled over checked my hoses to see if my thermostat had opened and it the hose felt warm but not as warm as the other hose from my radiator so then I got in and drove home n the gauge went back to normal and I just changed my thermostat, coolant temp sensor and thermostat temp sensor if u have ANY idea wht cld be wrong let me know
Djmorfintime is offline   Reply With Quote
Old 11-19-2013, 12:38 PM   #2
Flyin_bryan
Flyin_bryan's Avatar
Flyin_bryan is an unknown quantity at this point
if i had to guess i would say it had an air pocket in the cooling system.
Flyin_bryan is offline   Reply With Quote
Old 11-19-2013, 12:42 PM   #3
Djmorfintime
I bled the system tho? u think I shld bleed it again?
Old 11-19-2013, 01:11 PM   #4
PPman
PPman is an unknown quantity at this point
When I flushed the radiator and changed the fluid it happened to me a few times I had to take short drives and add more coolant as I went since my driveway is inclined the air bubbles in the system were a pain.
PPman is offline   Reply With Quote
Old 11-19-2013, 01:15 PM   #5
Djmorfintime
same here ppman did it eventualy stop?
Old 11-19-2013, 01:36 PM   #6
tiggertsi
tiggertsi is an unknown quantity at this point
i've experienced the same problem after changing my water pump and radiator. water pump was bad. the radiator became bad when i tried to remove the hose from the top the plastic just fell apart. and in my case it was air pockets. i had to bleed the system a few times before the temp gauge would stay consistent. and that was over a week of driving it back and forwards to work, etc.
i'd advise bleeding it more maybe over a week and watching what the temp gauge does. if it continues after a few bleeds you may want to look into something else.
66 Plymouth Satellite, 96 Nissan 240sx, 03 Harley Sportster. Toys!
tiggertsi is offline   Reply With Quote
Old 11-19-2013, 01:40 PM   #7
Djmorfintime
ok ill look into tht ill try bleeding it again
Old 12-20-2013, 07:59 PM   #8
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
KA's can be notoriously bitchy to bleed. Jack up a bit, and put a funnel adapter kit on it and let it idle.
mr.nismo. is offline   Reply With Quote
Old 12-20-2013, 08:42 PM   #9
Scope240sx
Scope240sx's Avatar
Scope240sx is an unknown quantity at this point
OP did you try topping off your coolant yet?
had the same issue when I changed all that stuff & I didn't put enough coolant in.
GL
Scope240sx is offline   Reply With Quote
Old 12-20-2013, 09:08 PM   #10
240sxfan6882
240sxfan6882's Avatar
240sxfan6882 is an unknown quantity at this point
Coming from a long time ka owner that's swapped coolant a million times on it:
Get oem thermostat.
Buy this: Lisle 24610 Spill-Free Funnel : Amazon.com : Automotive
Or install this:
Amazon.com: Circuit Sports Coolant Breather Tank: Automotive
//End thread//
240sxfan6882 is offline   Reply With Quote
Old 12-21-2013, 12:23 AM   #11
PPman
Yes it stopped after adding coolant like five times. I should have just let it idle with the cap removed while adding as needed, maybe giving it a few revs that worked on my Toyota T100.
cooling system, help 240sx, overheating, s13
