Old 09-06-2004, 04:27 PM   #1
Shin_Kudo
Shin_Kudo is an unknown quantity at this point
Door sensor problem?
When I open my doors, the dome light doesn't come on, and the car doesn't beep, even if the keys are in the ignition. I don't think it could be the sensors themselves, as it's unlikely that both would not work. I know it's not the light, and turning it on manually works, and the beeping is still absent. Any idea what the problem could be?
'95 240SX Base Pearl White
Shin_Kudo is offline   Reply With Quote
Old 09-06-2004, 04:34 PM   #2
nismo skyline
nismo skyline's Avatar
nismo skyline is a well-known jackass
i hate that damn dinging sound, especially when ur working on the car. consider urself lucky
nismo skyline is offline   Reply With Quote
Old 09-06-2004, 05:29 PM   #3
Nissandriver714
Nissandriver714 is an unknown quantity at this point
check your fuses
Nissandriver714 is offline   Reply With Quote
Old 09-06-2004, 05:49 PM   #4
AlligatorBling
AlligatorBling's Avatar
AlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choices
Send a message via AIM to AlligatorBling Send a message via Yahoo to AlligatorBling
lol, so true.
AlligatorBling is offline   Reply With Quote
Old 09-06-2004, 06:28 PM   #5
Ritz S14
Ritz S14's Avatar
Just do what I did and unplug the damn thing. 2 wires going to a yellow box(white plug).
Ritz S14 is offline   Reply With Quote
Old 09-06-2004, 09:37 PM   #6
projectRDM
projectRDM's Avatar
Only the driver's door trips the key buzzer.
You didn't state what year your car is, on S14s there is a 'smart entrnace control' unit, it controls the doorlocks, domelight, key buzzer, and rear defogger timer. On S13s there's a 'timing control' unit, similiar to the S14 but does less functions, that could be bad.
FORMERLY R240NA
Old 09-06-2004, 10:18 PM   #7
Shin_Kudo
I've got an S14. Don't think it's the SEC, as I have manual locks, and my defogger functions properly.
Old 09-06-2004, 10:18 PM   #8
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
Uhh.. it's because the previous owner removed all the sensors and shit..
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 09-06-2004, 10:23 PM   #9
Shin_Kudo
Oh, did he? Wish he'd told me before he sold me the car. Not a big deal, but I still would like to have known....
Old 09-06-2004, 10:28 PM   #10
holisticbeatz
Errr.. I don't know...
Old 09-07-2004, 12:53 AM   #11
idlafie
idlafie's Avatar
Could be a couple of things....(before you start though, check your fuses first)...could be a bad fuse...doubtful though...but better to be safe.
1). When you turn your car on, or put the ignition to ACC, do you see the little Open Door symbol on your dash?? If you do, then it shouldn't be the door wires.
2). Does your car have a car alarm?? Is it stock or aftermarket? Stock should work...unless the smart entrance control unit no longer works....or the wire has been cut leading to the dome light - this applies to both stock & aftermarket
3). Have you checked the dome light itself?? I believe the switch is a three way switch..and slides both left AND right...one of those positions is the OFF position...one is the manual ON position & the other is the DOOR open/ON position. Try sliding the switch & opening the doors...see if that works.
4). As for the door chime, the previous owner probably just disconnected it. It's easy to reach underneath the dash & disconnect the harness. Stick your head underneath the dashboard & look around for a small harness hanging down next to a small white square box. Plug that harness into the box & your door chime should start working again.
Anyhow, try this stuff...see if it helps...
Good luck!!
ID
'95 SE
Old 09-07-2004, 12:58 AM   #12
projectRDM
projectRDM's Avatar
Cars without locks have a defogger timer, and a then a separate buzzer/domelight control unit, so that could be your problem after all. You'll see two distinct units under the dash, to the left of the column. I forget which one is which, but you'll know by trial and error.
FORMERLY R240NA
Old 09-07-2004, 01:00 AM   #13
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
or the wires could have been taken out for weight savings.
http://bhworld.wordpress.com/
Old 09-07-2004, 01:18 AM   #14
Shin_Kudo
Could have been? As if you don't know?!
Old 09-07-2004, 01:30 AM   #15
Brian
Brian's Avatar
Trader Rating: (54)
i state facts.
not opinions.
i win.
Old 09-07-2004, 10:19 AM   #16
Colorado S14
Colorado S14 is on the path to ruinColorado S14 is on the path to ruin
I have a similar problem on my S14 that I just cannot figure out. When I open the passenger door the door buzzer will work and so will the door ajar light, but the dome does not. The dome light does, however, work with the passenger door and the dome switch. It is so annoying, any ideas?
Colorado S14 is offline   Reply With Quote
