Bee*R problem
Purchased a Bee*R so i could have a non fuel cut rev limiter. Ive been playing with it quite a bit here lately to correct my problem. But any setting above 6k and sometimes 5k will cause the car to start misfiring terribly after i come off the limiter. It only takes about 5-10 seconds for the car to clear up and be back to normal, but this renders the limiter useless. It doesnt seem to make any difference when i adjust the gain, 1-F makes no difference.
I switched from NGK 6 coppers to BKR6EIX (.032 gap) and its helped a tad. Im wondering if its just the nature of the beast or something that could be corrected. I do have a TERRIBLE unknown valvetrain tick that i think might be messing with knock sensor, but im not sure on that. Maybe a hotter plug? I did clean the MAF sensor with a cleaner. Stock SR20DET redtop running 10-12psi. Thanks for the help guys. |
![]() Join Date: Nov 2010
Gap plugs to .028.
Also coil packs are sometimes old and worn out so it might be a faulty coil
Z32 with lq4 swap Desert Street Scene || Dssevents.com |
![]() Join Date: Mar 2012
You will break a rocker arm with this fitted on an SR
I think Bee R themselves don't recommend it used as a limiter only the launch control via the handbrake (E brake) I busted a rocker on like the 5th time I hit the limiter no RAS I was asking for trouble Wrecked the cam lobe and one rocker shim fell down oil return at back of the head,so had to drop both sumps https://fbcdn-sphotos-c-a.akamaihd.n..._3943428_n.jpg |
#6 | |
