Old 11-21-2013, 06:31 PM   #1
Ichiban4
Ichiban4's Avatar
Ichiban4 is an unknown quantity at this point
My Block Ruined? (Head studs gone bad)
After trying to clean out my block multiple times to get the studs in evenly and many failed attempts I get them pretty close so I figured it should be ok
I get the head on and begin torquing the nuts done, 20lbs went fine, then on 40 lbs I started on the center one and it started getting tight and then all the sudden started free spinning. I turned it a couple more times to see if anything happened and nothing, so I put and allen head in and took the stud out.
This metal shaving was twirled all in the threads..
Now I tried putting the stud back in and it seems to thread in fine but I don't know what to do. Any experience? I paid a lot to have this block refinished it's going to really suck if the stud holes are toast or should I rethread it back in and try again?
arp btw
☆ Panda Pirates ☆
Ichiban4 is offline   Reply With Quote
Old 11-21-2013, 06:33 PM   #2
jr_ss
Helicoil or another thread repair kit and you should be good to go.
Old 11-21-2013, 06:37 PM   #3
sil14zenki
sil14zenki's Avatar
Trader Rating: (25)
sil14zenki is an unknown quantity at this point
Feedback Score: 25 reviews
def do not thread back in... look up "time inserts". i've used them on head bolts and flywheel to crank bolts and they've held up just fine. make sure the threads are still good on the arp studs
sil14zenki is offline   Reply With Quote
Old 11-21-2013, 07:38 PM   #4
Sileighty_85
Sileighty_85's Avatar
Yikes man how hard did you thread it in there, should only be until they bottom out.
Having a Machine shop install a Helicoil would be your safest best bet.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-21-2013, 07:40 PM   #5
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
ARP hardware seems to destroy SR's.
Old 11-21-2013, 07:44 PM   #6
Ichiban4
Ichiban4's Avatar
Are the pulsar arp studs the same length? They are 12mm so I could just drill mine out and retap them for 12mm.
I feel more comfortable tapping to 12mm and not using those little insert things :/
☆ Panda Pirates ☆
Old 11-21-2013, 08:07 PM   #7
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
I had this happen to me a few months ago.
DO NOT HELICOIL. Either buy a thread-sert kit for a B series honda and use the spacer provided for a B16 or take it to a machine shop to do it.
I make over 400 WHP BTW. My friend had this happen on his car also, he did the same thing and he made 875 WHP.
jorge1190 is offline   Reply With Quote
Old 11-21-2013, 08:56 PM   #8
tiggertsi
tiggertsi is an unknown quantity at this point
i'll second this advice!
66 Plymouth Satellite, 96 Nissan 240sx, 03 Harley Sportster. Toys!
tiggertsi is offline   Reply With Quote
Old 11-21-2013, 09:26 PM   #9
Rich260z
Rich260z is an unknown quantity at this point
That happened to on of the SR blocks I had. I brought it to Mazworx for them to check if it could be retapped. They said that the most solid way to do it would be to drill it out for the GTR head studs (12mm or 1/2) head studs, and they wouldn't do any work unless that was what I was going to do.
Just some food for thought. I found another good spare block for $50 less than an hour away from me.
Rich260z is offline   Reply With Quote
Old 11-21-2013, 09:47 PM   #10
Ichiban4
Ichiban4's Avatar
Yea I am leaning towards just having a shop tap them out to 12mm, if you go to 12.7 I think the head gasket needs to be modified.
So the rb26 gtr bolts are the correct length? I was gona go pulsar but i think they are only 155mm where as SR are 165-167. I suppose I will call arp tomorrow and see
☆ Panda Pirates ☆
Old 11-21-2013, 10:23 PM   #11
S14DB
AFC #1
S14DB's Avatar
TIME-SERT, Keensert, Keysert, Acme Threaded Inserts are all better than Heli-Coil's.
Old 11-21-2013, 10:40 PM   #12
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
This^^^^ or go to 1/2" headstuds and never worry about headlift again....
Drift_FX is offline   Reply With Quote
Old 11-25-2013, 04:04 PM   #13
Ichiban4
Ichiban4's Avatar
Just an update 4 of the 10 were stripped and I hadn't even tried torquing the others down yet so I am avoiding a repair kit and just decided to go with the mazworx 1/2" studs. They are pricey but at least I will have the peace of mind I don't have a band-aid covered block and head lift shouldnt be an issue. My machine shop said 100$ to drill the head and block or about 200$ to tap them all too, I can at least tap them myself if not do the drilling as well so after everything I will still be coming out around the same price as the Time -Sert kit.
☆ Panda Pirates ☆
Old 11-27-2013, 11:12 PM   #14
zurud
zurud is an unknown quantity at this point
if 4 out of 10 is stripped, your block is probably toast.. The block is soft and weak now from overheating. Better off get another block.
zurud is offline   Reply With Quote
Old 11-28-2013, 12:52 AM   #15
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
I will jump on the Time-sert wagon. Same thing happened to me while replacing a head gasket on a rover V8. I decided to repair the threads with time-serts myself. The truck has been running for over a year and 3K+ miles on it including a long distance trip through 100+ degree weather.
mxexux is offline   Reply With Quote
Old 11-28-2013, 10:01 AM   #16
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
We had this happen and the machine shop drilled and tapped The block for a larger bolt. Drilled and tapped the bolt for the stud and decked the block. Been working for two years or so
Black240Ct is offline   Reply With Quote
Old 12-01-2013, 07:20 PM   #17
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
dolts intalling (insert any brand here) hardware seems to destroy SR's.
Fixed for you. It's not 100% arp's fault. Most people either don't have the proper bottoming taps, or don't even clean out the threads and just slam them home. I've had so many engines with ARP's I can't even keep track, and I can't even tell you one that was stripped.
With that said, for the cost, there are better designed studs for those not cleaning everything up 100%.
Just let the machine shop do everything for you. That way you know it's straight, and know it's done properly. Not saying you're not capable, but you can't have them willly nilly or crooked in there in the least. If it was my moped engine or a lawn tractor, I'd try it...but nothing I care about.
Old 12-02-2013, 11:45 AM   #18
Def
You can make a drill bushing and a fixture to hold it, but at that point I'd pay the $100 to have them drill it. $200 to tap it seems excessive, so I'd probably do that myself. I'd think drilling/reaming it square would be by far the hardest part.
DEFSPORT
Old 12-04-2013, 08:36 PM   #19
Ichiban4
Ichiban4's Avatar
Just for those who haven't seen here is a comparison of the ARP Sr20 studs vs the Mazworx 1/2"
☆ Panda Pirates ☆
Old 12-04-2013, 08:39 PM   #20
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Do the 1/2" and never look back.
om3ga is offline   Reply With Quote
Old 12-04-2013, 09:58 PM   #21
slw240sx
slw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant future
Send a message via AIM to slw240sx
I would have the machine shop do this work. they are likely going to put it on to a machine and have the drilling and tapping done straighter then you can do by hand or with a drill press. Most regular shops do not even have a setup big enough. They are probably saying 200 to drill and tap. Thats not a bad deal to have it done right.
http://www.forcedfabllc.com/
slw240sx is offline   Reply With Quote
Old 12-05-2013, 08:22 AM   #22
Def
Larger headstuds can sometimes cause uneven head sealing due to the clamping force changing drastically as things heat up. That's why so many head studs are torque to yield - putting the stud/bolt in its plastic range with a thinner head stud gives you more room to play with on things expanding and still maintaining things in its elastic range at a given clamp load.
Lots of times I see the 1/2" head studs torqued to such a low number because that's what the head can take, but that means the studs are stretched so little that you either REALLY ramp up the clamp load as things grow, which then causes things to relax due to the high clamp pressures on the head (i.e. the head gives way).
In almost all things with engineering, you can't just say "more is always better." At some point you cause other problems, and fastener design is not as simple as the layman might think it is.
DEFSPORT
Old 12-05-2013, 01:18 PM   #23
Ichiban4
Ichiban4's Avatar
I am having a shop do all the work. For anyone in the future they are charging me $250 to drill and tap. They said they have done 1/2" in a couple Sr's before so I felt comfortable with them.
As far as the sizing and engineering aspect I know nothing about so I can't say much other than this kit was designed for the SR by Mazworx and ARP to withstand extreme boost on their high HP cars so I have complete confidence that it is a reliable choice for my car. Torque spec on these from Mazworx is 95ft. lbs so it is very similar to what the SR head usually gets. Also with about double the threads available in the block after tapping that alone will help with a lot of issues.
I will update again when it goes together hopefully this weekend.
☆ Panda Pirates ☆
Old 12-10-2013, 10:38 PM   #24
Ichiban4
Ichiban4's Avatar
Just an update/insight for future readers who may do the same.
Labor cost $250 to drill/tap/and fit the headgasket. I used a Apexi HG and the only 2 holes that needed to be drill larger were the 2 for the new larger dowels.
Torque spec on these is 65/85/95 although I went 20/40/60/80/90/95.
Few pics for comparison of size.
☆ Panda Pirates ☆
Old 12-10-2013, 11:57 PM   #25
aga
aga's Avatar
aga is an unknown quantity at this point
a good read, useful stuff. thanks.
My Build
aga is offline   Reply With Quote
Old 12-12-2013, 05:49 PM   #26
Def
95 ft-lbs on a coarser threaded fastener actually gives you LESS clamping force. Same torque on a fine thread fastener gives higher clamping loads due to the mechanical advantage of the finer thread.
Surprised the torque spec is that low honestly...
DEFSPORT
Old 12-12-2013, 10:00 PM   #27
codyace
codyace's Avatar
Trader Rating: (58)
Def, are you saying you'd think the ARP should be higher than the 85 ft lbs? For conversations sake I'd love to know the differences, as It just doesn't feel 'right' going beyond that....even on the torque wrench it feels bad.
Old 12-12-2013, 10:31 PM   #28
S14DB
AFC #1
S14DB's Avatar
Put some head studs in a Turbo Diesel. 85ft/lb is the initial tq...
Old 12-12-2013, 11:22 PM   #29
240ss
240ss's Avatar
240ss is an unknown quantity at this point
and your point? this isnt a diesel. You're talking major differences in cylinder pressures.
240ss is offline   Reply With Quote
Old 12-21-2013, 10:23 PM   #30
Matej
Trader Rating: (39)
Egads, just discovered a stripped thread.
Can I trust those Time-Sert things?
Time to buy a new engine.
