Alright guys, I've been using the search feature and haven't been able to find anything..
XXR 526 comes in 17x10 +20 My question is how would I get them to fit on my S14..I'm going 30mm wide fenders and going to use 25mm spacers up front. All tires are going to be 235/40. Am I going to have to use spacers in the rear? How much pull? Should I just go overs in the rear? |
#2 | |
I had 17x10 +15 on the rear of my last S14. It stuck out about 20-25mm. So it will probably stick out about 15-20mm in the rear, and fronts will stick out super far with 25mm spacers.
The rear would look ok, a little camber and stretch and it would sit flush-ish. The front is way too wide. Were talkin 50mm sticking out, even with 30mm overs up front, it will be 20mm outside those. If youre trying to get that Stretched Tire Huge LIP Look, then youre on the right track. Sent from my SGH-T989 using Tapatalk 2 |
#4 | |
#5 | |
Man w/ CTSV & a Car Seat
#7 | |
![]() Join Date: Feb 2012
![]() specs here are 17x9-35 (-10 w/ 25mm extended FLCAs) front and 17x9+15 rear I believe. lol
ACE マジック HEART |
Umm...how would pushing the wheels further out big you more steering angle? If it anything, shit will be worst since you'll rub in anything and everything.
#9 | |
Dont need more noobs reading this believing your wrong info and then posting more ignorance thinking theyve learned something. Sent from my SGH-T989 using Tapatalk 2 |
#10 | |
lolwut? More inner clearance = more steering angle and less rubbing. Pretty simple concept.
ACE マジック HEART |
#11 | |
#12 | |
![]() Join Date: Jul 2006
wider front track is for stability and turn in the added camber is beneficial when you're at full lock.
DODOlogic.ca |
True but it's mostly for inner fender/tension rod/FLCA clearance.
ACE マジック HEART |
