Old 01-05-2014, 11:36 AM   #24
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Originally Posted by crzsteveo View Post
I would prefer a welded diff over a LSD in a stock KA. just my two cents.
my daily has a ABS lsd and my track car has a welded. the lsd is a lot harder to break loose then my welded. but then again, I don't know how well the ABS models lsds work sssooo.
Aftermarket LSDs work A LOT better than the OEM Helical/Viscous units. Both OEM units are not full limited slips, but theyre both a thousand times better than the stock open diff.
I would only recommend you weld your diff ONLY if you plan on making your car track only. Welded diffs create a lot of excess wear on your tires if you daily drive the car. you will be going thru sets of rears every 3-6 months (if youre lucky). LSDs allow the wheels to spin at a different rotational speeds when making turns so you dont chew up your outer tire (if i remember correctly). with a welded diff, both tires spin at the same rate which is great for drifting, but horrible when youre trying to make a normal right turn in traffic and that outer tire starts burning itself.
dorkidori_s13 is offline
