#3031 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
So I'm gonna be running 18x9.5j-13et front and 18x9.5j+12et rears... I already have decided on running 225/40/18 tires in the rear, but what size tires would I need on the front to fit under stock metal fenders on an S14..? I was thinking 225/40/18 as well. I'm going to be running a lot of camber of course to fit these things... Unless it's fucking impossible to do it, then I'll take off the 25mm spacers I have so that it can be done.
Before anyone asks, reason for the spacers to make it lower offset even though I really don't need it, is because the wide track looks really cool to me. Unless of course taking off the spacers gives me the same look I'm going for, then the obvious solution is to remove them for good.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#3032 |
Man w/ CTSV & a Car Seat
Why would you want to run 50mm wider track up front when you have less space up front than the rear? You slap those 25mm spacers up front, kiss your full lock good bye. Shits gonna rub all over the place if you're slammed.
#3033 |
![]() Join Date: Sep 2012
![]() Feedback Score: 9 reviews
i dont know if this makes sense but i have a 18x9.5 +12 up front on my 13 hatch. what offset in 18x9 would make it similar to the fitment of the 9.5 +12? disregarding the tire size.
#3034 | ||
I assume that your 18x9.5 +12 either slightly pokes or is mostly flush, right? In back, you will want to come out about another 5mm-10mm. Why not run equal fitment all around and just run a 5mm spacer in back?
1996 Zenki 'Baraketsu Tenshi', Burst Angel My work in progress... |
#3037 |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
I highly doubt that you've taken any time or effort to answer your question. "Gonna take some work" is an understatement. S13 and stock fenders? You've got to be trolling.
#3038 | |
I've already hammered all the lips flat in the inner fender as well as pinch welds above the tire. The harness is relocated, and a bit of a roll/pull on the front fenders. I'm curious what size tire I should run, 235/40? I expect its going to rub pretty good so I'll just hammer/torch wherever necessary. |
#3040 | |
#3041 |
![]() Join Date: Feb 2013
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Ok need some help, s14 on coil overs with adjustable rlca, ruca, and toe arms fenders are rolled flat maybe a super slight pull. 10.5j x 18 +20 for rear I want to run a 265/35/18 or would a 255/35/18 fit better? How much pull would I need? To keep camber less than 3*. I tried a 285/30/18 I had laying around and have like over a inch of wheel sticking out
#3042 |
Whos running the Federal 595 RSRs for daily driving? Im looking for 195/50r15 front and 205/50r15 for my Z and kinda considering those. Hows the thread life looking?
Also if anyone else has recommendations for matching pairs in those sizes, im all ears. =)
Keep it Classy |
#3043 |
RSRs are comparable to the RT615s in my opinion. They're sticky at first but they lose their grip once they get harder. I think they're lower tier tires compared to the likes of Dunlop Star Specs/IIs, RE-11s, Hankook RS3s, AD08s, and PS2s. Kicker is, those tires are going to be more expensive and harder to find for your size.
Personally, I prefer symetrical threads over assymetrical ones. Gives you the option to flip the tires when/if you get too much camber wear, so I'm partial to Dunlop, RS3 and AD08. |
#3045 | |
Retired General
In other words, it doesn't matter haha |
#3046 |
Ok i am about to buy a set of wheels that are 18x10.5 with 0 offset fronts and 18x11.5 with 0 offset rears. on my s13 hatch i have 20mm front over fenders and 50mm rear over fenders. i know the rear wheels will fit but i am not 100% sure about the front wheels. i am running 25mm extended lower control arms and run -6.5 camber in the front. if anyone out there can give me some advise on this i would really appricate it! thanks guys!!!
#3057 |
#3058 |
I cant see the picture so I'm not sure if its an S13 or S14. Either way, you can MAKE those wheels fit on stock body. Just a matter of how much fender pulling you want to do, stretch tires and camber. Easier to do on an S14 than an S13.
#3059 |
So I got Weds Kranze LXZ 18x10 (+12) & 18x10.5 (+6) and I am wondering what tire size to you guys recommend. I was thinking of getting some Falken 912's sized 215/35 for the fronts and 225/40 for the rears. What's your guys opinion on this? On a S14 btw. Thanks.
#3060 | |
