Old 04-13-2014, 02:07 PM   #1
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
5 speed swap, won't start thread.
I fired it up right before I did the 5 speed swap, turned on fine. No issues.
I did a complete 5 speed swap with the exception of the ECU, lower harness.
Now the car won't start, It's not even turning over. BUT when I turn direct wire my starter to my battery it starts up fine.
I did the inhibitor switch jump, I have no other clues on where to go.
Here's the 4 plug right next to the fuse box, did I miss anything?
IG: @ozc2jz
oscarsx is offline   Reply With Quote
Old 04-13-2014, 02:11 PM   #2
92SEric240sx
92SEric240sx's Avatar
Trader Rating: (32)
92SEric240sx is an unknown quantity at this point
Feedback Score: 32 reviews
What lower (transmission) harness did you use?, the starter signal comes from that harness, it's best to use one from a manual car with the 5 speed conversion
RELAX BRO!!!!
92SEric240sx is offline   Reply With Quote
Old 04-13-2014, 02:14 PM   #3
oscarsx
oscarsx's Avatar
I used the Auto harness, I don't have my 5 speed harness available yet.
IG: @ozc2jz
Old 04-13-2014, 02:16 PM   #4
92SEric240sx
Trader Rating: (32)
Power and ground to the right spot on the starter? Check your grounds
RELAX BRO!!!!
Old 04-13-2014, 02:25 PM   #5
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
....this guy.....search!! And you will find the answer. You don't need a manual harness.
Ilya is offline   Reply With Quote
Old 04-13-2014, 03:14 PM   #6
oscarsx
oscarsx's Avatar
I've searched for hours since I've found this problem
IG: @ozc2jz
Old 04-13-2014, 03:21 PM   #7
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
Guessing thats an s14? Looks to be loose ground or signal wire for the starter not connected. You don't need an manual harness to get it running but some of the warning lights will be on (for s13 anyway).
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 04-13-2014, 03:25 PM   #8
Ilya
Ilya's Avatar
Solder Solder Solder!!! looks like you twisted two wires together. come on man, there are like 4 wires inside a 240 and you cant figure it out why you had a good starter before, and now you dont.
Did you disconnect the starter to do your swap?
Have you tried tapping the starter and then starting?
Did you check your battery?
Old 04-13-2014, 04:45 PM   #9
Chaluska
never solder in the engine bay.. always use crimps
engine = hot. solder melts in heat.
Old 04-13-2014, 04:53 PM   #10
SkyS13Walker
SkyS13Walker's Avatar
SkyS13Walker is an unknown quantity at this point
Send a message via AIM to SkyS13Walker
Get a manual ecu and check all your grounds
Love her like ya bitch and i aint talkin about ya girl
SkyS13Walker is offline   Reply With Quote
Old 04-13-2014, 05:23 PM   #11
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
If your engine gets hot enough to melt the solder, I believe you have another issue. Would have to get extremely hot for it to melt the solder unless you use cheap crap that melts with light heat.
Also, to the OP, you may want to look at a diagram to see where all the wires for the starter go too so you know which start the starter and which may not be as important. You can also try using a remote starter switch, turn the key to ON position and try turning over the engine. In theory, should start unless you are missing more connectors and wires. Go over everything you did and make sure there are no missing connectors. I know you said it starts up fine so really just sounds like you didnt connect something correct. Tripple check it all and make sure it is all correct.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 04-13-2014, 05:42 PM   #12
oscarsx
oscarsx's Avatar
I agree with the solder, that ghetto twist was for a quick fire up and check ☑ it was good. But your right. I'm going to check everything else.
I checked all fuses and relays with my other s14 no solution. I know I'm missing something very stupid. I ran out of ideas. All my swap consisted of basic junk no wires for the exception for the speed sensor, o2 and the crank angle sensor.
- oz
IG: @ozc2jz
Old 04-13-2014, 05:59 PM   #13
Ilya
Ilya's Avatar
Make sure you sand the stranded wires a bit, they are covered with coating that makes soldering a bitch.
Old 04-13-2014, 06:11 PM   #14
oscarsx
oscarsx's Avatar
I already did, I had to pull out my heavy duty soldering needle lol. Also my battery terminal broke off, I'm seriously hoping that was the issue.
- oz
IG: @ozc2jz
Old 04-13-2014, 06:12 PM   #15
oscarsx
oscarsx's Avatar
Attachment 69428
- oz
IG: @ozc2jz
Old 04-13-2014, 09:45 PM   #16
Ilya
Ilya's Avatar
Good luck and report back with the results
Old 04-14-2014, 03:50 AM   #17
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
If you have warning lights you screwed up and need to figure out what you did wrong. I have done a few of these swaps on S13s and never used the manual harness and have not once tripped any warning lights because of it.
OP replace that whole red connector if the metal bit that connects to the battery is starting to break, it will one day snap on you leaving you possibly stranded. I would not suggest buying a new OEM one as you are just getting yourself into the problem again later down the road.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 04-14-2014, 08:32 AM   #18
s14boy
Trader Rating: (26)
s14boy is an unknown quantity at this point
Feedback Score: 26 reviews
Get your self a dmm and check for 12v at the 12v post. Check for continuity to the negative battery terminal to make sure your starter is getting a good ground source. And lastly check to see that you are getting voltage when you key is in the "cranking position. To do this attach you dmm to ground and to the signal wire on the starter and have some one crank the car. If you have power and ground but no voltage to the signal wire then grab your self a fsm and trace the wire to see what your problem is.
-Mike
s14boy is offline   Reply With Quote
Old 04-14-2014, 09:58 AM   #19
oscarsx
oscarsx's Avatar
Replaced the terminal and still no success.. What I did find out tho is that my Alternator is bad. I've been using up all my battery juice and I'm hoping that was causing this issue.
My lights would dim out while the car is on, everything would flicker. My car would run like crap, I did the good ol ghetto check your alternator method, disconnecting the positive cable (stupid I know) and it died. So I'm picking one up today...
If this does not fix the issue, I swear I'm just going to push start method lol.
IG: @ozc2jz
Old 04-15-2014, 02:28 PM   #20
oscarsx
oscarsx's Avatar
Second alternator and still no solution. All my alternators tested seem to be bad. I'm replacing the 100 amp fuse today.. Already swapped out my 75amp and no progress.
- oz
IG: @ozc2jz
Old 04-16-2014, 05:53 PM   #21
oscarsx
oscarsx's Avatar
So I installed a working alternator and my car still won't start. I have to jump the starter directly to the battery. I'm honestly confused and I have no where to start.
I'm seriously just thinking of adding a on/off switch directly from the start/battery cable lol. ghetto push start.. but I rather not If i can fix it the right way.
IG: @ozc2jz
Old 04-16-2014, 06:15 PM   #22
ATLspeed
ATLspeed's Avatar
You are def right. I'm thinking of when my engine bay harness was cut from being lowered. . Everything was fine when I switch to an uncut harness
OP There is def something wrong with the signal wire to the starter. If you have a volt meter check to see if you are getting a 12v signal when turning the key to start.
95 Supra Turbo
Old 04-16-2014, 08:15 PM   #23
oscarsx
oscarsx's Avatar
I'm getting 0 voltage lol, so there's a start. Going to back trace a bit and read up on the fsm.
Anyone have any idea and where to start.?
- oz
IG: @ozc2jz
Old 04-16-2014, 11:15 PM   #24
zerodameaon
That situation is always fun to deal with.
OP did you take out any of the little computer boxes for the auto like the green one under the drivers dash or the one hidden up behind the ECU? Also for the short start with all the wires that hook up to the starter and use the FSM to trace them back to their origin.
It might be your ignition so check that.
http://forums.nicoclub.com/1991-1994...l-t249966.html
Old 04-16-2014, 11:26 PM   #25
oscarsx
oscarsx's Avatar
I did take out the one where the clutch pedal goes, I believe that's for the automatic trans... a module, correct me if I'm wrong.
As for the other one, I did not remove that one.. should i?
thanks for the link I'll read it up tomorrow at work. thanks
IG: @ozc2jz
Old 04-17-2014, 12:51 AM   #26
zerodameaon
Leave the one up by the ECU it won't affect anything badly, as for the green one put it back and try again, all it is supposed to do is be the shift lock unit and it is supposed to keep you from removing the key without the car in park(not possible with no auto trans anymore), but maybe its causing some unknown issues.
