Old 05-13-2014, 10:10 AM   #1
joedirt513
joedirt513 is an unknown quantity at this point
89 coupe, sr20 built motor, caged lots of upgrades
ok so im selling my drift car, because im leaving for the year, maybe longer. not for street use track car only. sr20 Motor just rebuilt forged JE pistons with pro seal rings, arp head studs, tubular manifold, 18g turbo. modified front knuckles megan tie rods inner and outer. 4 piston brembo calipers from evo 9 on front with brand new drilled and slotted rotors, ss lines arp extended studs with rota grid wheels. full cage built to formula d sped, tig welded, stock seat brackets removed and replaced with 1x1 tubing that is sleeved for mounting bolts, big hump in floor for stock cat removed and replaced with flat sheet metal to allow for lower seat position. straight pipe exhaust, comes with welded rear diff and vlsd currently installed, tube front end, lexan windows, coil overs, brand new ichiban 5 lug front hubs aem wideband, autometer water and boost guage. runs like a champ im sure I'm forgetting stuff, call or text if you have any questions, serious buyers only please.
10k
513.520.7902
joedirt513 is offline   Reply With Quote
Old 05-13-2014, 10:17 AM   #2
joedirt513
drift car
text for more pictures, the whole interior is painted white now along with the cage. dimple died gussets along a pillar.
brembo brakes, drift car for sale, sr20 240 s13 sr20det
