Old 07-02-2014, 10:22 PM   #1
soontoownahatch
soontoownahatch is an unknown quantity at this point
s14 brake upgrade question
When upgrading to a z32 brake master cylinder and z32 calipers I can still use my stock hardline into the master and the stock s14 soft line into the caliper when upgrading correct? front upgrade only right now
soontoownahatch is offline   Reply With Quote
Old 07-02-2014, 10:37 PM   #2
estanislao
estanislao's Avatar
estanislao is an unknown quantity at this point
Your gonna have to bend one of the hard lines to the mc. And you will have to buy conversion lines. Frsports sells them pretty cheap.
estanislao is offline   Reply With Quote
Old 07-02-2014, 11:53 PM   #3
Kingtal0n
Kingtal0n's Avatar
I would do the brakes first. Then see how they feel to you.
You might not mind the way they feel with the stock master.
tinyurl.com/4l80er
Old 07-03-2014, 01:01 AM   #4
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
also id look at the size of your master cylinder since automatic s14's come with a 15/16 master and thicker brake booster for assistance, and if i remember right there was one year on z32 that came with a 15/16 so id try bolting up thoze calipers with proper conversion lines / rotor set up and try it out and see how you like the pedal feel.
also just a tip, on thoze stock brake lines in the wheel wells where they transfer over from hard line to soft the 10mm bolt is easy to strip so id pb blast it or wd40 like a day prior and use a flare wrench to have more surface contact to avoid stripping.
GL
Renelovesnike is offline   Reply With Quote
Old 07-03-2014, 06:43 AM   #5
soontoownahatch
OK perfect yeah my car was a 95 s14 automatic so if they are both 15/16 I'll start with the stock one and go from there.
What pad do you guys recommend for front?? This will be a street driven v8 with occasional drift
Old 07-03-2014, 09:01 AM   #6
JBB
JBB is an unknown quantity at this point
hawk hps pads
http://www.frsport.com/DIF-10042-300...X_p_15334.html
http://www.frsport.com/Brembo-40206-...m_p_15411.html
http://www.frsport.com/Hawk-HB178F-5...96_p_2259.html
JBB is offline   Reply With Quote
Old 07-03-2014, 03:03 PM   #7
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
Yea, I ran the HPS on Z32 front/rear on my S14 and they worked great for daily and a few short course track days.
Not noisey, dont require any real warm up like some full race pads, and dont dust too bad for a higher performance pad.
Sales @ Enjuku
email:[email protected] phone:352-241-8399
Prok0 is offline   Reply With Quote
Old 07-03-2014, 07:31 PM   #8
jr_ss
I have a 4pot Wilwood setup upfront using Z rears with the stock S14 MC and booster.
Old 07-09-2014, 01:01 PM   #9
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
Verify the size of your master cylinder. My 97 auto has a 7/8" MC. But I understand the auto brake booster provides more assist. The S14 with ABS came with 15/16" MCs.
I think I'm using Centric ceramic pads. Currently also in the process of upgrading to a 1" Z32 MC and retrofitting ABS.
LoSt180 is offline   Reply With Quote
