Old 07-08-2014, 09:19 AM   #4111
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
So maybe my question was a bit vague, so I'll reword it:
I saw a guy running a "flywheel adapter" as such on a 2JZ+CD00x: (small round piece within the blue adapter)
I was wondering what you guys are running for the flywheel and/or adapting the flywheel to fit. If the flywheel is a "custom" piece, where are you guys getting it besides @Maverick? (http://www.maverick-motorsports.com/...-adapter-plate)
My iTrader rating!
babowc is offline   Reply With Quote
Old 07-08-2014, 03:09 PM   #4112
S13project
S13project's Avatar
S13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of light
2JZGTE Swapped S-Chassis thread
Finally got a couple pics of the CX cable bracket
File Type: jpg ImageUploadedByTapatalk1404853727.008030.jpg (251.1 KB, 35 views)
File Type: jpg ImageUploadedByTapatalk1404853737.291077.jpg (240.1 KB, 33 views)
S13project is offline   Reply With Quote
Old 07-08-2014, 03:20 PM   #4113
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Yo my bracket didn't line up worth shit on my non vvti 2jz! I have one of these for sale if anyone wants it for their 2JZ VVTI
$40 Shipped
BiG MiKE86 is offline   Reply With Quote
Old 07-09-2014, 08:08 AM   #4114
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
there is no adapter plate, the kit that Collins Adapter sells the flywheel looks to be a 2jz flywheel but but with z33 pressure plate bolt pattern so any single plate z33 clutch on the market works.
as for the right spacing for the Throw out bearing to pressure plate he also includes a new throwout bearing housing that is longer.
JohanM is offline   Reply With Quote
Old 07-09-2014, 08:27 AM   #4115
babowc
babowc's Avatar
Johan, is it the same thickness as a 2JZ flywheel or thicker like Maverick's fw?
My iTrader rating!
Old 07-09-2014, 08:33 AM   #4116
JohanM
JohanM's Avatar
pretty sure its an standard 2jz flywheel.
Old 07-09-2014, 09:58 AM   #4117
babowc
babowc's Avatar
Sorry to keep asking, but does it have dual patterns, then?
1 set for the 2JZ PP and another for the Z33 PP?
I assume the friction pad is the same size...
My iTrader rating!
Old 07-09-2014, 10:52 AM   #4118
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
Hey guys, just wanted to chime in on my Maverick plate.
We use a CUSTOM thickness flywheel specifically designed to work with ANY 350z clutch.
The OEM 2jz flywheel is thinner than my setup. This causes the splines on the clutch disk to only ~ half engage. I wasn't too comfortable with that that is why my flywheel is thicker. It allows for full engagement of the splines and also places the TOB where it needs to be without over-extending it.
Hopefully that clears it up!
-George
PS. I bounce around forums so if you have some specific questions please email me for quickest response.
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 07-09-2014, 01:27 PM   #4119
Cronus577
Cronus577's Avatar
Cronus577 is an unknown quantity at this point
I've been looking at the Maverick JZ to VQ adapter full kit, and I was wondering where that would put the shifting placement inside the car, if it was too long the shifter would be in my console and that wouldn't be fun
Cronus577 is offline   Reply With Quote
Old 07-09-2014, 03:44 PM   #4120
babowc
babowc's Avatar
-George
Is that even after you mill the bellhousing?
I thought the bellhousing was machined 3/8" or the thickness of the adapter so that the input shaft makes full contact with the pilot bearing & disc spline?
My iTrader rating!
Old 07-09-2014, 03:49 PM   #4121
soundboy
soundboy is an unknown quantity at this point
Anyone using a automatic swap?
soundboy is offline   Reply With Quote
Old 07-09-2014, 04:17 PM   #4122
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
You have to machine off 1/2in. Anything more than that then you just weaken the bellhousing mount points in my opinion.
*For anyone who is going with the z33 trans and tries to take the bellhousing off, there is another 12mm bolt that is hidden under the black cover that holds the bell housing on...wasted so much time because of not knowing that.
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 07-09-2014, 04:33 PM   #4123
maverickmotorsports
The milling is more for the input shaft.
But it also helps keep the flywheel from becoming even thicker than it needs to be.
There is a new shifter design that is being tested right now. It should place it in the OEM location.
-George Marstanovic
Old 07-09-2014, 07:19 PM   #4124
ATLspeed
ATLspeed's Avatar
Yyeeesss!! I will hold off on buying a shortened shifter housing/extension if it keeps me from cutting. I've only seen 2 setups that sit in stock location so far. One with reverse lockout and the other directly on the shifter rod without lockout.
95 Supra Turbo
Old 07-10-2014, 10:29 AM   #4125
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
Is this the one you are referring to?
Mr. Phonso is offline   Reply With Quote
Old 07-10-2014, 10:37 AM   #4126
ATLspeed
ATLspeed's Avatar
^^^ Yes that's one and the other is with a vk56 s13. He used heim joints for his. (Here is the build if anyone likes looking at goodies http://www.stanceworks.com/forums/sh...ad.php?t=50721)
95 Supra Turbo
Old 07-12-2014, 02:31 PM   #4127
XxS13LifexX
XxS13LifexX's Avatar
XxS13LifexX is an unknown quantity at this point
So I have a question I was hoping you guys could help me out with.. I purchased a vvti 1jz that I'm pretty sure came out of a Toyota Crown. I bought it before realizing it may or may not have an ignition immobilizer wired in.. so I guess my first question is:
Would anyone know what plug/wires to look for on a jzs171 or jzx110 ecu wiring harness?
And if it does turn out that it has the ignition immobilizer, would it be possible for me to buy an aftermarket push button start like these options:
http://m.aliexpress.com/item/1956779...bilesitedetail
http://www.advancedkeys.com/Prod_AK104B.html
And then wipe the ecu immobilizer code and reset it with the aftermarket push button starts RFID code? I really hope this option will work because I wouldn't mind swapping it in..
Thanks for any help!
Tim
XxS13LifexX is offline   Reply With Quote
Old 07-14-2014, 05:56 PM   #4128
ta2dpnoy
ta2dpnoy is an unknown quantity at this point
I hooked up the dakota box on my s14. my speedometer is still not working. power and ground are ok. theres a write up on here but it's for an s13 and he made his own harness.
I cut pin 26 wire (RED). I put one end which is the vss side to the input of the dakota box, the other end which is the cluster side i put it on output1. is this right?
transmission is an r154 which is a 3pin vss that has a sensor ground which i did not connect. do i have to connect that one for this to work?
thanks
ta2dpnoy is offline   Reply With Quote
Old 07-14-2014, 06:02 PM   #4129
ta2dpnoy
diagram of how i did. is this correct?
Old 07-15-2014, 12:18 PM   #4130
ta2dpnoy
nvm got it to work
Old 07-15-2014, 02:58 PM   #4131
Mr. Phonso
yea you need the ground for the toyota sensor to work.
there should be two wires in the fuse box area that went to the old 2 wire nissan speed sensor.
toyota speed sensor is 3 wire
1 goes to the ground on the dakota unit
toyota vss output wire will go to one of the wires that was cut from the nissan sensor (I forget wire colour but it should output a 2.25V when the key is ON)
the other remaining wire from the nissan 2 wire vss plug does not get used if I remember correctly.
find a source from the fuse box area to wire switched 12v to your toyota vss
When you wire in the dakota all you need to do is intercept the toyota vvs output wire.
Old 07-15-2014, 05:16 PM   #4132
ta2dpnoy
I got all that. I'ts just frustrating that I thought I would be able to use either one of the nissan wires that goes to the speedo. Red wire didn't work, Red/yellow did.
Old 07-17-2014, 07:49 AM   #4133
BiG MiKE86
BiG MiKE86's Avatar
Anyone whos running AEM V2 and the map sensor - where did you mount it? Pics?
Old 07-17-2014, 09:55 PM   #4134
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
'92 HB HX35 rb25 - sold
'89 Coupe GTX35 VVT-I 2JZ - yeah buddy
AS240 is offline   Reply With Quote
Old 07-17-2014, 10:06 PM   #4135
BiG MiKE86
BiG MiKE86's Avatar
Originally Posted by AS240 View Post
Did you have to re-tap that hole?
Old 07-17-2014, 10:40 PM   #4136
AS240
AS240's Avatar
Trader Rating: (18)
Nope. I'm not sure what was there before though.
Old 07-18-2014, 07:57 AM   #4137
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
I'm running aem v2 with a map and had to re tap the hole for 1/8" npt. You just remove that round filter and re tap it for the map.
Follow me on Ig- Andydennington
91ka24 is offline   Reply With Quote
Old 07-18-2014, 09:30 AM   #4138
BiG MiKE86
BiG MiKE86's Avatar
Sweet thanks man. I've got a 1/8" NPT tap here I'm going to try and run through the hole today
Old 07-18-2014, 10:36 AM   #4139
rswails
rswails is an unknown quantity at this point
Ight guys I'm at wits end here trying to get my s14 2jz gte with stock twins to fit with the heater hoses hooked up as well. I have tried xcessive mounts, and ebay mounts and neither have enough room it appears to hook up heat. Xcessive says the mounts work with twins, but I don't think they will work either unless you guys have a solution.
Anyone know how this can work or anyone I can talk to who made this work? If so what mounts did you use? How did you manage the heater hoses?
Any help is appreciated.
I know it will easily fit if I go single, but i don't want single at this time. I also think I can make it work if I weld a forward extension on the xmember, but that is not going to be easy. Also, it might work if I push in the heator core spouts on the firewall while trying to bolt the engine up, but I'm scared it will break off the spouts
rswails is offline   Reply With Quote
Old 07-18-2014, 10:39 AM   #4140
supercompact
supercompact is an unknown quantity at this point
It was my understanding that you can't run heat on a s-chassis on stock twins. You can loop the heater hoses together and bypass the heater core in the car, but you obviously won't have a working heater.
supercompact is offline   Reply With Quote
