The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
![]() SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM. LOCATION: Los Angeles, CA PAYMENT OPTIONS: Cash, Paypal ![]() S13 Parts List S13 Exterior RH Quarter Panel Replacement RH Lower Rocker Panel Non-Sunroof / Slicktop Replacement Roof for S13 Hatchback Front Bumper Upper Retainer Zenki S13 Front Bumper Support Front Fender Brackets Headlight Metal Lid Headlight Splash Guards (plastic, sit on radiator core support) Hood Prop Hood Hinges Hood Latch Cowl Trim Covers Wiper Arms Wiper Motor LH Door Glass Window Exterior Door Handle Rear Bumper Cover Rear Bumper Support Rear Bumper Brackets Rear Bumper Foam S13 Hatchback Taillight Set S13 Hatchback Taillight Metal Garnish S13 Hatchback Trunk 3rd Brake Light Fuel Filler Door LH or RH S13 Hatchback Exterior A-pillar Trim B-Pillar Plastic Exterior Trim Front Amber Fender Sidemarkers Rear Red Sidemarkers S13 Hatchback LH or RH Quarter Windows (no trim) S13 Interior S13 Hatchback Ignition/Doors/Trunk/Glove Box Lock Set with Key Steering Column Lower Steering Column Cover Dash Plastic Vents / Tubing (behind dash) RH Dash Vent Blower Motor Heater Core Box AC Core Box Antenna Wiring Harness LH or RH Door Frame Trim Finisher LH or RH Interior Door Handles LH or RH Interior Door Handle Bezel LH or RH Interior Door Handle Pull Plastic Trim RH Door Grab Handle LH Manual Window Regulator Window Crank Handle w/bezel LH or RH Triangle Mirror Covers LH or RH Door Latch Door Assembly LH or RH Door Lock Rods LH or RH Door Misc Brackets LH or RH Speaker Brackets Radio Brackets Din Pocket Glovebox (no handle) S13 Factory Non-AC Climate Control Set LH Seat Plastic Trim RH Auto Seat Belt Track LH or RH Lap Belt LH or RH Shoulder Belt Rear Seat Belt Buckles S13 Hatchback Rear Seat Belts LH or RH Kick Panels (Black) S13 Hatchback Rear Large Plastic Trim set S13 Hatchback Rear Speaker Metal Brackets S13 Hatchback Non-Sunroof Headliner Dome Light Trunk Light Fuel Pump Metal Cover Misc Interior Brackets Misc Interior Buttons (Headlight, Hazard, Defroster, Dimmer, etc) S13 Suspension / Brakes Front Knuckles Front Lower Control Arm Set Steering Rack Steering Rack U-Joint Front Brake Caliper Set Rear Brake Caliper Set Emergency Brake Cable Set Rear Lower Control Arm Set Rear Upper Control Arm Set Rear Traction Rod Set Rear Toe Arm Set Rear Subframe Brace Rear Subframe Stud Set Diff Cover Welded Diff (Non-ABS, 4.08 ring gear, 6-bolt shafts) OEM Axle Set Rear 4-lug Hubs Front/Rear OEM Shock and Spring Set (newer KYB) Front or Rear OEM Sway Bar Brake Master Cylinder Brake / Fuel Hard Lines S13 Engine Bay KA24E Complete Air Intake Set (Tubing, filter box, etc) KA24E Engine Block KA24E Cylinder Head KA24E Valve Cover KA24E Intake Manifold Bare KA24E Throttle Body KA24E Fuel Rail KA24E Distributor KA24E Alternator KA24E Power Steering Pump KA24E Power Steering Reservoir KA24E MAF Sensor KA24E Ignition Coil KA24E Misc Pulleys KA24E / KA24DE Emissions Components Misc KA24E Engine/Block Brackets / Parts Charcoal Canister OEM Radiator w/hoses Windshield Wiper Tank w/filler neck Fuel Filter Bracket S14 Parts List S14 Exterior OEM S14 Kouki USDM Sideskirt Set OEM S14 Zenki Leather Nose Mask LH or RH Quarter Panel Replacement (complete cut out) LH or RH Rocker Panel Replacement LH or RH Strut Tower Radiator Core Support LH or RH Frame Rails Rear Subframe Stud Set LH or RH Door Shell LH or RH Exterior Door Handle LH or RH Door Check / Stop LH or RH Door Belt Trim LH or RH S14 Zenki Fender S14 Zenki Hood Hood Hinges Hood Latch S14 Zenki Hood Prop S14 Zenki Front Bumper S14 Zenki Fog Light Delete Trim S14 Zenki Headlight Set S14 Zenki Corner Lights S14 Zenki Turn Signals S14 Zenki Front Bumper Support w/ Retainer S14 Zenki Front Bumper to Fender Brackets Windshield Wiper Cowl Trim Windshield Wiper Set Wiper Rotating Arm Assembly S14 Zenki Wiper Motor Rain Gutter / A-Pillar Exterior Trim Wingless Trunk Trunk Support Arms 3rd Brake Light S14 Zenki Taillight Set Rear Bumper Cover Rear Bumper Support Rear Bumper Brackets License Plate Light Front Windshield LH or RH Door Glass LH or RH Door Mirror Rear Windshield / Glass Rear Glass Lower Trim Finisher Rear Tow Hook Fuel Filler Door S14 Interior S14 Zenki Black Cluster Cluster Bezel Dash Metal Brace LH or RH Dash Vents (lead to door panels) Steering Column Trim (2pc with ignition trim) Lower Steering Column Trim Steering Column Throttle Pedal with Cable Throttle Pedal Stopper Dead Pedal Wiper Switch Turn Signal Switch Wiper/Signal Holder Bracket Steering Wheel Clock Spring Glovebox (no latch) Glovebox Bracket Center Console Side view mirror switch Ash tray Radio Brackets Climate Control Panel Blower Motor Heater Core Box AC Core Box Dash Vent Piping / Ducts Emergency Brake Handle LH or RH Door Panel LH or RH Interior Door Handle LH or RH Window Regulator LH or RH Door Handle Bezel LH or RH Door Lock Latch Assembly LH or RH Door Lock Rods LH or RH Door Misc Brackets Cigarette Lighter Sun Visor Set A-Pillar Set B/C Pillar Set Front and Rear Seat Set (OEM Gray) Rear Seat Swivel Brackets Rear Seat Striker Bracket Front Seat Belt Set Front Seat Belt Buckles Rear Seat Belt Set Rear Seat Belt Buckles Rear Seat Large Interior Plastics Rear Seat Trim Finisher (behind seats) Rear Speaker Deck Lid Light Dimmer Switch Hazard Light Switch Defroster Switch Cruise Control Switch LH or RH Kick Panel Door Sill Set LH or RH Door Frame Seal / Finisher Trim LH or RH A-Pillar Window Frame Seal Trunk Carpet Panels Set Trunk Rubber Seal Trunk Latch Trunk Striker Trunk Edge Plastic Trim Cover Fuel Pump Cover Trunk Light Jack with Mounting Bracket Misc Interior Brackets (Dash, doors, interior panels, trunk, etc) S14 Suspension / Brakes OEM 5-lug Front and Rear Hub Set OEM 4-lug Front and Rear Hub Set Front Knuckles Set Front Lower Control Arm Set Front Crossmember Front Brake Caliper Set Steering Rack Steering Rack U-Joint Rear Upright / Knuckle Set Rear Lower Control Arm Set Rear Upper Control Arm Set Rear Lower Toe Arm Set Rear Upper Traction Rod Set Rear Subframe Brace Rear Brake Caliper Set Emergency Brake Cable Set Rear Subframe Tunnel Bracket / Brace Brake / Fuel Hard Lines Set Fuel Tank Straps Fuel Tank Heat Shield Fuel Filler Neck S14 Engine Bay Zenki AC System Complete Set (Compressor, Condenser, all lines, brackets, etc) Zenki MAF Sensor Charcoal Canister Complete Air Intake System (intake pipe, air filter box, all ducting) Cruise Control Assembly Heater Core Hoses Power Steering Cooling Hard Lines Fuel Filter Mounting Bracket Radiator Radiator Mounting Brackets |
