Old 08-06-2014, 10:07 AM   #1
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
s14 strut bars that fit on s14 with sr20?
I had a tcs sportline strut bar that slightly touches my valve cover on my s14 sr with nismo mounts. Are there any name brand strut bars that actually clears? Cusco, apexi, nismo etc.
SilviaSR20DET is offline   Reply With Quote
Old 08-06-2014, 11:04 AM   #2
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Nismo mounts tend to raise the engine. So you have a few bars that will probably always touch. Simply look at designs. Some have more clearance than others.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 08-06-2014, 11:19 AM   #3
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
S14 SRs require quite a bit of room for clearance, youre going to have to experiment with different strut bars until you find one that fits due to the giant hump in the middle of the valve cover coupled with your NISMO mounts.
fun fact, nissan incorporated the OEM catchcan on the redtop/black SR20det into the valve covers on the S14/S15 notchtop motors... hence why theres a giant hump in the middle.
Old 08-06-2014, 03:34 PM   #4
jr_ss
Cusco bars seem to clear. Mine did on my S14 Sr swap. I haven't tested it with the VVL swap.
Old 08-06-2014, 04:08 PM   #5
Def
Let me know how the clearance is with the P11 VC vs. the S14/S15 VC.
My S13 Steal Custom Fab bar (which is awesome BTW) just barely fit with my S15 SR. I just skimmed a bit of the logo with an angle grinder to give it some more clearance, so it should be fine.
DEFSPORT
Old 08-06-2014, 05:25 PM   #6
SilviaSR20DET
thanks for all the response, most likely ill go with cusco cause it looks nice haha. Ill keep you guys posted if i end up getting one that clears so people know where to look in the future.
Old 08-06-2014, 05:28 PM   #7
SilviaSR20DET
Do you know what type of cusco bar you used? Its with the nismo mounts right?
Old 08-06-2014, 06:18 PM   #8
jr_ss
I believe it is a Cusco Type 40D. Yes, that was with Nismo mounts.
I'll let you know once I get the end plates cleaned and painted. My guess is that it's going to be tighter than the S14/15 VC because of the height of the intake side of the VC.
Old 08-06-2014, 08:33 PM   #9
fatduece
fatduece is an unknown quantity at this point
Does anybody know if the gt spec struts clear?
fatduece is offline   Reply With Quote
Old 09-26-2014, 09:43 AM   #10
SilviaSR20DET
I wanted to update this thread for those who ran into this problem. All i did was buy a engine damper which uses a strut tower plate and just install it and it will space out the strut bar a lil higher so it clears perfectly and should with most strut bars. Easy fix!
Old 09-26-2014, 01:19 PM   #11
eek
Trader Rating: (29)
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Feedback Score: 29 reviews
Or if your baller enough you can get the nagisa skakitto plates which will also raise it up.
eek is offline   Reply With Quote
