Old 10-07-2004, 10:21 AM   #1
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
fuel pump hardwire/rewire
anyone know if its possible? or anyone done it before here in san jose willing to help me out? basically i want the fuel pump to run off its own power source but still connect to my ECU for the stock prime effect...
i did a search and came up with the 30amp relay conversion... just wondering if this owuld get rid of my problem with the shorting wires causing my car not to start sometimes.
thanks
-ryan..
s13silady is offline   Reply With Quote
Old 10-07-2004, 10:26 AM   #2
Dousan_PG
Dousan_PG's Avatar
yeah possible
find the power line on the harness
easy to do. super easy
mega easy
break out the FSM
Aaron
Pink GodziRa
Old 10-07-2004, 10:33 AM   #3
msaskin
msaskin is an unknown quantity at this point
Send a message via AIM to msaskin
Relay in trunk near fuel pump.
10-12ga. power wire direct from battery to input on relay.
Stock fuel pump power wire to + trigger on relay
Ground - (neg.) trigger and neg pole of relay to chassis
Stock fuel pump power will flip the relay, which in turn will power the fuel pump directly from the battery.
Worst case scenario and you blow the relay, just reconnect the stock wires and call it a day.
~matt
it's not turbo lag...it's foreplay
'01 Ford Excursion Limited.
Powerstroke Diesel
Coming in spring: ???
msaskin is offline   Reply With Quote
Old 10-10-2004, 05:00 AM   #4
s13silady
s13silady's Avatar
ok quick recap... i hardwired my fuel pump completely with its own power source (battery), independant ground, and new relay. and i spliced into the ignition wire of my turbo timer...fuel pump gets power no problem at all.. the cars still not starting... so my other buddy with an SR stops by and lets me swap ignitor chips to see if this was the cause... same thing no go...
it just cranks and cranks and cranks.. doesnt turn over all the way...
a shop told me that the power leak is coming from ignition relay... i have yet to check that will do first thing in the morning...(oh and also my coil packs..)
can someone also tell me where the ignition relay is located? (seems dumb but im having a small problem trying to find it...)
SR20DET redtop...in a 90FB...
if anyone can throw out suggestions that would help me trouble shoot id be very greatful...
CLIFFNOTES: my car cranks..doesnt turn over.. rewired fuel pump.. works good now...checked for spark..none...checked ignitor chip, and not the problem...
Old 10-10-2004, 12:23 PM   #5
s13silady
s13silady's Avatar
anyone????
Old 10-10-2004, 12:57 PM   #6
proj240sx
proj240sx's Avatar
proj240sx is an unknown quantity at this point
did you pull your plugs out and check to see if they are even sparking?
edit: whoops sorry
90 RPS1345 hybrid thingy & 01 IS300
proj240sx is offline   Reply With Quote
Old 10-10-2004, 01:04 PM   #7
s13silady
s13silady's Avatar
"...checked for spark.."
yes i did...
Old 10-10-2004, 01:19 PM   #8
kickertu
kickertu is a well-known jackass
might be a wiring issue..
i know this is dumb.. but is your ecu screwed into the harness?
kickertu is offline   Reply With Quote
Old 10-10-2004, 07:23 PM   #9
driftstyre
driftstyre's Avatar
driftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond reputedriftstyre has a reputation beyond repute
Send a message via AIM to driftstyre
The IGN Relay is in the fuse box in front of the passenger fender. The fuel pump (IGN Pump) relay is right next to that. I recently had a similar problem and ended up re-timing the crank angle sensor and the engine ran but would misfire under load conditions. The more I turned the CAS clockwise the better it ran. If you're getting spark and fuel it most likely is your CAS as its firing at the completly wrong times.
driftstyre is offline   Reply With Quote
Old 10-10-2004, 08:29 PM   #10
s13silady
s13silady's Avatar
i thought it was my cas too.. but if a cas were to go out it would have more of a chance to go out mechanically and not electrically... the problem i have is an intermittant (sp?) problem.. so it has to be electrical... im going to have my wiring checked out first thing monday... ill keep posted...
oh and also i see a lot of people lately have been having fuel pump issues so im going to do a write up for the fuel pump relay mod with pics as soon as i get this problem squared...
Old 10-10-2004, 11:51 PM   #11
AN89HATCH
AN89HATCH is a well-known jackass
check your distributor cap and rotor
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 10-11-2004, 01:48 AM   #12
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
He has a RWD SR20DET.
I was glossing over the post and I just read it... seems you did it all wrong dude. That's why its not working. You're looking for the solution in all of the wrong places.
GO search FA under username "Enthalpy," he posted a very simple schematic on how to do it.
Good luck
kazuo is offline   Reply With Quote
Old 10-11-2004, 02:28 AM   #13
s13silady
s13silady's Avatar
haha.. thats what i followed... did exactly the same.. it works.. but its another problem thats not starting my car...im just saying ill do a write/up with pics because the enthalpy way doesnt have pics..
little update: i switched the EGI and the EGI pump relays under the hood and the car started... but i waiting to see when its going to go out again...when relays go out its usually intermittant... so im going to see if this was the problem...
yah i checked my cap and rotor and replaced my spark plug wires also.. still no go... and i made sure my blinker fluid is good... jk.
Old 10-21-2004, 12:50 AM   #14
s13silady
s13silady's Avatar
ok... i thought i solved the problem... but i didnt... i thought it was just the fuel pump relay and ignition relay in the box under the hood... its not...
so im beginning to think it is either my main relay, or my ignition lockswitch...
those would be the best bets on why i have this problem...do any of you guys have any idea? or at least know if im on the right track..? i dont want to spend $150 for a new main relay and have it not be the problem...
if it does turn out to be my main relay, it would be located somewhere under my dash i assume (correct me if im wrong)
if any of you are in the san jose area and willing to help me out with this problem to check i would greatly appreciate it and or pay.. its been been a month now and this problem is a mystery still...
Old 10-21-2004, 01:06 AM   #15
kazuo
You need a multimeter, a FSM and a lot of patience.
I say you bypass your stock wiring, run your own power/ground wires to the pump, and wire a relay in the back. Make sure the power wire has a fuse inline.
That way, you cut out the bullshit and get the problem solved ASAP.
Total cost = less than $50 and itll take like an hour or two
I think Enthalpy also posted how to do it on FA? It's not too hard...
Old 10-21-2004, 01:10 AM   #16
s13silady
s13silady's Avatar
ive done that...but i have arised to the new problem of not getting any spark... a shop told me that the problem was sourced to the ignition relay... but im thinking that its the main relay... but i dont know how to get to it..
Old 10-21-2004, 01:18 AM   #17
kazuo
All the relays are right there in the engine bay in the fuse box. Big ass green ones IIRC.
I dunno what your problem is... if you bypassed it it should work fine... if you're not getting spark, you have bigger fish to fry.
Good luck
Old 10-21-2004, 09:50 AM   #18
s13silady
s13silady's Avatar
well i was told the MAIN RELAY is under the dash somewhere... i just need this clarified..
