#4381 |
Tweak'd did my harness and highly recommend them if you are looking for a place to get it done. If you are doing it yourself contact rswails on here, he was working on a how to guide I believe.
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
#4384 |
![]() Join Date: Feb 2007
i need help.
my car won't fire. i already know it's the injectors not firing. fuel is getting to the rail i'm running bosch 750cc high imp the injectors fire if i use a 9v battery to test the solenoid. so they are not stuck. the harness is all custom. i have deleted the stock resistor box. i run a direct 12v line from ignition to the injectors and then from the injectors directly to the ecu. with ign on i get 12v at the injector plugs. my multimeter isn't able to see the ecu pulse but i'm getting my hands on a noid set tomorrow. ecu is an aem v2 and i have used the wizard to select the correct injectors ideas? |
#4385 | |
#4386 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Had the same issue with mine. Turned out to be a setting in the V2 that was off. I'm running FIC 775cc high imp and AEM V2. Have someone knowledgeable With the v2 look at it
#4388 |
You said the harness was custom, did you check every connection back to the ECU with a multimeter?
#4390 |
Try these links :
2JZ wiring - http://tinyurl.com/lo7j7ry 2JZ wiring in s14 - http://tinyurl.com/n2ude5j |
#4391 | |
I'm sure the s13/14 side of the wiring from those links would come in handy but he was asking about a 2j VVTi which is a wiring nightmare compared to the non VVTi.
#4395 |
#4396 |
#4398 | |
#4399 |
Ya my motor was in good shape. But I could tell the valve seals were worn in a couple cylinders. But I'm an overkill kind of guy. So I'm doing a full build. I need to start a build thread. Ha
#4400 |
![]() Join Date: Apr 2007
So over the past few weeks i've noticed some poor connections on the wiring to the connectors due to the OEM 20 year old terminals going bad, Anyone know a place i can get a bunch of terminals for wiring for a decent price other than Elmhurst Toyota?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
#4401 |
![]() Join Date: Oct 2012
Each plug has a number on it you can Google the numbers and find the plugs, think I paid about $130 for every plug on the harness with pins and little rubber insulator things
#4403 |
#4406 |
2JZGTE Swapped S-Chassis thread
Have you compared to a non VVTi? Not saying it's impossible but it's no walk in the park 9 wires like the non VVTi
#4408 |
Having trouble with my Dakota Digital SGI-8 (Tach Signal Converter) I plugged in into my wiring specialties harness that had the leads for it and Im getting no movement to my tach. The box lights up (flashes). Im running AEM V2, wiring specialties harness, Non-vvti 2JZ-GTE, JDM Cluster, S13. Any ideas? Anyone have the settings for the DD box?
Thanks
#4409 |
#4410 |
![]() Join Date: Sep 2010
How is you brake booster ran? My 2j has the port on top of the intake plenum but we just picked up my wife's 2j and it doesn't have the port
Follow me on Ig- Andydennington |
