Old 10-13-2004, 08:12 PM   #7
Touring240
Touring240 is on a distinguished road
Go buy:
5 lug s14 SE rotors
new rear brake pads
2 new cotter pins
remove cotter pins and locking cap
remove 36mm nut
remove 4 bolts holding the hub to the spindle
(turn the rear axle to gain access to each bolt, its a bitch)
pull off rear hub (borrow/rent a hub puller if you want it makes things easier especially if its a rusty car)
If you just have the hub not the hub and bearing assembly you'll have to buy a new bearing or reuse your old bearings and get them pressed on.
Install is the reverse of the removal.
Touring240 is offline   Reply With Quote
