Old 10-20-2014, 09:28 AM   #1
omgwtf
omgwtf's Avatar
omgwtf is an unknown quantity at this point
Yeah that's what I'm thinking. I jumped the big terminal on the starter to the small one and it turned over. After that the ignition switch worked. When i turn the key it gives the starter signal wire 10 volts for like a second then it goes to 12 volts. Are the advance ignition switches any good or should I just go with a junkyard one?
omgwtf is offline   Reply With Quote
