![]() For Sale is my 1997 240sx kouki silver moss. I have had the car for a little over 4 years and I'm thinking of moving on to something else. Here is some info on the car:
The car had a damaged radiator support which I replaced when I had the car repainted. I also replaced the the hood with an OEM part from Duarte nissan. The car does have a clean title but it was involved in some kind of fender bender. I never asked the person I bought it from for details. Below are some of the details and parts on the car: -167k on chassis, SE model -sr20det s13 blacktop, refreshed, new oem piston rings, acl race rod and main bearings, valve job on cylinder head, all seals replaced, only 1k still breaking in -new exedy clutch, fidanza flywheel with replaced friction plate (very soft great for daily driving) -nismo pilot bearing -t28 journal bearing bearing turbo, with clocking kit -ISIS turbo lines -turbo gaskets replaced -rocker arm stoppers -greddy intake filter -wiring specialties upper and lower harnesses -koyo radiator -koyo radiator drain plug -silcone hoses through out entire engine -ngr BOV -GKtech fan -mishimoto front mount intercooler -drift works crash bar -rsr downpipe -greddy turbo elbow -blitz turbo timer with built in boost gauge -Circuit sports turbo timer harness -nrg cooling plate -led in gauge cluster -fortune auto 500 coilovers, barely installed 500 miles ago, great ride -Apexi noir full exhaust, very quiet, deep tone -no name test pipe -energy suspension rear subframe bushings -walbro fuel pump -nismo type a FPR -jdm front bumper -jdm grill -17x9 +17 work kai reps gunmetal, have curb rash -federal 595 tires -300z 28mm aluminium calipers -SS front brake lines -sustec lower brace -gtspec upper tower brace -unknown tension rods -4x hubs replaced -OEM kouki rear wing -DDM 4300k HID kit -isis thermostat -water pump replaced with OEM unit -o2 sensor replaced with OEM unit -cody ace a/c bracket -replaced front and rear transmission seals -replaced lower shifter boot -full interior -pioneer head unit with bluetooth -registered good until June 2015 -ignition switch replaced (common nissan issue) -circuit sports short hub -driver side door key cylinder replaced from dealer Cons -rear defroster does not work -very small dent on passenger side fender -1 crack on dash on driver side -a/c needs recharge, most likely I will get it done -driver side door card has a different pattern -chips on front bumper from road debris -sunroof cover is broken -trunk cable does not work Asking price $9500 obo, make an offer worst thing I can say is no. This is my project car so it does not get much use and I'm in no rush to get rid of it. So if anyone is interested just PM me, thank you. Location is Los Angeles. ![]() ![]() ![]() ![]() ![]() Last edited by unitrak750; 12-10-2014 at 12:35 PM.. Reason: changing post details |
